Aurora
I have a Minolta F spot meter and a Gossen Luna Pro incident meter.
I am slightly confused.
Let´s´take a couple of scenarios.
I am in a landscape. It´s sunny with lots of shadows. Some shades I don´t care for, but some I do. So if I have the possibility to creep under or in the shade I could take an incident reading and have 2 -3 stops less. That would give adequate texture for the shadows, placing it on Zone III or II.
With the spot meter I could spot read the shade - which would make that Zone V (this is the bit I am confused about), then I do the same, it makes that zone V so I need to close down 2-3 stops. I could also have it on a different ISO, first finding out what EI that film is.
On the Minolta spot meter there is an S button, for shadow. Could I just click on that one - spot metering in the shade and it would give me the correct reading? It seems like that from my understanding of the meter.
Doing the same for the highlights, calculate the SBR which is high EV minus low EV plus 5, no? Then I decide on what development it needs.
Now I´m in the landscape again, it´s snowy, cloudy and quite miserable.
I find the Shadow and highlight. Or in such a case, it´s quite safe to do an incident reading? As the brightness range is not going to be that huge. Of course if I want it to have more contrast I would need to calculate the SBR and give N+ dev. Although sometimes I like the photographs to look a bit "eastern european"…
A portrait in soft light, no harsh shadows- I could take an incident reading and leave it like that.
I also (and this is quite handy often) take a spot meter of the face. If the person is not snow white - I open up one stop, no?
I know it´s better to take a spot meter reading of the whole frame and decide the shadow in comparison to the face and highlights.
Sometimes there is no time for that, so it´s handy with a spot meter reading of the face. Another way is to take an incident reading.
A portrait with lots harsh light. How do you measure a face in such a situation?
Thanks in advance
Thanks in advance
