Spot on Inside of Lens
camera.bear
8:44 PM
Phoenix, AZ
Hey Everybody,
I got this 100mm lens to use with my Argus C3. I bought this on ebay and it came with a spot on the inside of the rear element. Does anyone know what it is and what I need to do to fix it or is it irrepairable? I tried to clean it but it is on the inside.
I was able to solve this one. I took out the rear element which turned out to be an air-spaced doublet which had gotten oil between the lenses. I cleaned this and reassembled the lens. 😀
I will be taking my C-3 and the 100mm, 50mm and 35mm lenses out for a test run this weekend. It should be fun.
