Spring in film tulip—Help
girdwoodINC
born under a bad sign
5:14 PM
Sunny Scotland
So the spring that’s in the film tulip of the quick loading system on my MP fell out last night - thankfully my sister in law found it…is this going to be an easy fix or a send away, any recommendations for the U.K. ?
Had managed to load a roll last night after I heard something drop but didn’t realise at the time, wondering whether to just sacrifice this now
I checked my M4 and it looks like the spring is just pressed into the tulip. It’s probably there to keep the film from being pushed too deep into the tulip. I’d push it in and see if it falls out easily, if if falls right out a tiny twist in an unwinding direction should increase the diameter slightly.
Your mileage may vary, only making a suggestion of what I’d do.
Not much help but similar issue in this thread. Might be an interference fit between the spring and tulip. My M6 is tucked away so can’t check it right now.
…And I’m assuming the spring/tulip configurations are similar across the various models - although I’m not sure about parts interchangeability.
