Landberg
Will the fix damage the negatives if i fix to long?
You test your fix times by popping some of the trimmed leader in fixer and time until it clears. Do this in a film canister or similar. This also lets you recycle your fixer:just test again. Fixer won't destroy your developed images.
So when the film is in the fix i can open the tank? How long does it have stay in the fix before i can open the tank?
Just fix the film for double the time it takes for the bit of leader to clear. I've left film in fixer for up to 15 mins (when 5 would do the job) when concentrating on the dev of another film for instance. Not sure how leaving it for longer e.g. hours would affect the film...
The longer you leave film in fixer, the more thoroughly the fixing agent penetrates the emulsion and the harder it is to remove afterwards. Ultimately, emulsions left with too much fixer in them fade as the fixer dissolves the silver grains.
If you leave film in fixer for hours unattended, the fixer will likely just dissolve most of the silver grains leaving you a blank film.
G
suggestion from a few decades of developing film: before you buy any hardware that is photo specific, take a tour through the houseware / kitchen department of your local discount store.
a bag of wooden clothespins (32 for $1-) work just as well as photo specific weighted stainless steel clips.
a $5- electronic kitchen timer keeps time just as well as a $125 Gralab photo timer.
Some large cheap kitchen measuring cups measure as well as the Kodak or Paterson ones at 20X the price.
A large stainless spoon stirs just as well as a Kodak stirring rod.
The list goes on and on. Just use your imagination.
