Stranded on an Island Scenario
RayPA
Ignore It (It'll go away)
6:22 AM
The GOLDEN State
Ok here is the scenario:
You're going to be stranded on an infinitely photograph-able island for a year with your favorite camera, BUT you can only take one b&w film with you and one developer, no other option exists.
Which film and developer do you take?
For those of you who process your own film, figure that you'll have the capabilities to process your own film and control the development, and for those of you that don't process your own film assume that you can have your film processed to your specifications. So let's here your picks. 😛
Any darkroom chemicals that are flammable so I could light the film boxes on fire for a signal fire once I was thru shooting.
Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala Scala
Assuming that island isn't NYC, then either apx100 or fp4+ & rodinal.
If it's NYC, then Tri-X and Diafine.
What to choose...
I love the look of the Delta films made by Ilford, but I'm also a fan of Tri-X. I'd probably choose Delta 400 if I was stranded with one film even though I like both equally.
Stephanie Brim said:
What to choose...
Stephanie,
I've used the TMax films, but not the Deltas, although I keep hearing good things about them. What developer would you use to process your Delta 400?
T_om said:
Problem is, your jug of D-76 wouldn't last a year. Diafine would. 🙂
Tri-X and Diafine.
Tom
O contraire. I use D-76 1:1, one-shot. I mix a gallon and divide it up into 16-oz plastic bottles. A unopened bottle will keep that long and even an opened one does pretty well if you squeeze out most of the extra air.
Actually I could probably survive with HC 110 and the syrup has a very long shelf life.
