Strap recommendation for my M3
CopperB
M3 Noob
10:45 AM
Ontario
I'm looking for a strap for my M3 that will protect the lugs and camera as much as possible. Currently I'm using an old strap with a leather lug protector on one side and a vinyl one on the other. A sales person at Downtown Camera in Toronto warned me about the metal rings wearing the lugs down over time.
Suggestions of what to look for and where?
Many thanks.
yes, metal rings will wear down the lugs over time, but the question is the amount of time. I am sure it has happened, but I have never seen a camera where the metal strap lugs had worn through. If nothing else, you could wrap the rings in gaffer tape if you were that concerned. As to straps, the best small strap I have ever used is the basic thin Nikon strap, available new at pretty much any flcs, or over the internet. It isn't plastered with advertising, and the section with the grip is both incredibly grippy as well as completely flexible. I know there are a few other folks here that also swear by this strap.
Here's a photo of my very heavily used Nikon F (several years heavy pro use hanging on a strap with metal rings). And a detail of the lug. You've probably got nothing to worry about. 🙂
Leica has a line of leather straps with their simulated animal print patterns on them for a high price. Avoid. My brand conscious friend bought the black Ostrich one and it sucks.
The basic Leica strap (14312) has plastic clasps to protect the body, a shoulder pad that will not slip, and a simple and elegant quick-release system.
(By the time any strap wears its way through the lugs, the only creatures left to care will be the cockroaches)
As others have said, don't worry about the lugs. Domke gripper straps have a leather protection piece between the strap hardware and the camera body. The strap is threaded through both the ring and the protector. It's not really necessary, but it's there.
attachment.php
Sorry about the big ugly pic. It was posted previously here in haste.
I have, and not just once, either.
I looked at that at B&H site. The shipping to Canada is as much as the cost of the strap. Maybe when I hit the store next summer I'll check it out in person.
i use a Domke gripper with the leather protectors. The protectors mainly protect the body. I'm not as concerned about the lugs because in the unlikely event that they are too worn out from use, they can be replaced.
--Warren
No good stories, alas. Or, perhaps, fortunately. As far as I recall, when it happened to me it was an M2, and again as far as I recall, it cost surprisingly little to have both lugs replaced with (yet again as far as I recall) Nikon stainless steel ones. It was a long time ago, and I had it done professionally: it's not an uncommon problem with hard-used M2s and M3s. I'd been watching the lugs getting thinner and thinner until one of them JUST parted (sharp edges standing proud: not enough to let the strap through, but so that I didn't want to pull and find out. I've seen it on a few other Leicas too. Twisting the lug is not much use because it tends to twist back again to the former position, for obvious reasons.
