Strap recommendations for Leica M5
Robert Lai
9:52 AM
I know that there have been threads from several years ago on this subject. The strap lugs of the M5 require a flat strap without split rings.
One thread asked for the original Leica M5 strap.
I wouldn't recommend any old leather strap for a camera, even if it is made by (or for) Leica. That ancient leather strap is just going to break one day, and the camera is going to go crashing down.
Other people have recommended the Domke gripper:
https://www.bhphotovideo.com/c/product/16174-REG/Domke_740_6BK_1_Web_Camera_Strap.html
Op tech EZ comfort strap:
https://www.bhphotovideo.com/c/prod...A_2701252_E_Z_Comfort_Strap_Black.html?sts=pi
My personal recommendation is Nikon's AN-48:
https://www.bhphotovideo.com/c/product/37064-REG/Nikon_639_AN_4B_Nylon_Neck_Strap.html
The Nikon exudes quality.
Unlike the Domke, it has the least number of geegaws and attachments onto the strap.
Unlike the Op-Tech, its shoulder pad isn't so springy that you fear the pad and strap are just going to rip apart if the going gets heavy.
Also, the Nikon strap has NO labeling on the strap itself, except for tiny "Nikon" logos cast into the plastic buckles.
Yes, you can pay a lot and get custom straps made by Luigi et al., but I think these ones here represent the most readily available and usable straps. I've bought all of them at one time or another.
I don't have any reason for recommending B&H except that they're the people that I've purchased from. I'm posting this just to summarize my experience for any future M5 buyers.
I read this comment on B&H about the Nikon strap:
"Nicely made, narrow strap. But it is only 48" long end to end before you attach your camera. So unless you only want to wear it around your neck and have your camera sit high on your chest, find a different strap. Trouble is that most of the narrow straps are also on the short side."
I use the Op Tech with my Nikon F6 and it is incredible as to how much lighter and more comfortable it makes the camera feel on my shoulder. My M5 w/ Nokton 50 1.1 is a heavy set up and the Nikon strap u link to looks too thin to be comfortable.
Hi Huss,
The Nikon strap is 1 inch wide. It has a thin pad of rubber on the inside surface for grip.
I'm 5' 10" in height, which is the median North American male height.
With my M5, the camera will tuck in at my waist if I sling it diagonally across from one shoulder. If I just let it hang from my neck, it goes down to my umbilicus. This is at the height that I've set it at. At its greatest extent, it could go down a 2 more inches on each side.
As for weight, for an M5, the strap is wide enough. The strap material is softly flexible, and not stiff either.
I have the two lug model. Thinking about buying a piece of unfinished leather strap and bringing it to the shoemaker to sew it together like a belt. The straps mentioned above do not slide from "holster" position to eye position.
FWIW, on the website of Gordy's Camera Straps, it says 40" is a typical and common length for neck straps. I'm not familiar with the Nikon straps; maybe some of their length gets used up by being doubled back at the attachment points?
I have a 3 lugs M5. I happened to have a leather strap that I custom order while I bought my GF1, and it works perfectly on the M5. Each side is adjustable like belt, I've also tried the Gordy strap(which works good too) and the Leica OEM M5 strap(it's designed for 2 lugs, which I'm not used to the carrying position)).
Well, for the past 30 minutes or so I have been walking around my room with a 135mm f/2.8 Elmarit (the one with goggles) on my M5, and a Metz 40-MZ-3i flash (with 4 AA batteries) in the hot shoe, and an Arca Swiss type quick release tripod plate on the bottom. Using the Nikon strap.
I'm not dying with this setup.
The hip actually takes up most of the weight when you wear the camera diagonally across. The strap is soft enough that it drapes over the the back and shoulder to spread the load.
I doubt that your Nokton is THIS heavy.
I like the straps from Contax cameras. After experience with the G1/G2 cameras I bought a few extra straps from KEH. They are an elegant grey leather with non-slip suede surface on the inner side, and then each end has a length of narrow nylon material. There are also wider ones that I think were for the Contax SLRs. Very nice straps at very modest cost.
I was really disappointed with the strap that came with a newer Leica M, shiny and slippery on the inner surface... slides off my shoulder too easily.
I totally agree with Robert, the Nikon AN-4B strap is a bit of a hidden gem in my opinion. I use it with my M5 and it is perfect. Actually, I use it on all my other M's and my Nikons! For me it is pretty much the perfect strap. Nikon used to supply it free with certain models, it's tough, discreet and most importantly doesn't get in the way. For me it would be hard to beat and I've used them for years.
Regards
Simon
Hi Huss,
Thanks for the extra info Robert, I'll look into it as I am your size.
I took some pictures of it, along with the original case. But realized its hard to explain through pictures, so I just made a short video about the strap and case.
Leica M5 original strap and case
That is really really helpful! It turns out I actually have one of those straps (didn't know what it was actually) but the leather is all brittle. I am going to have a new one made. And I agree, that case situation does not look very useful other than for storage in a bag.
I have like 4 Nikon AN-4B as my go-to no frills straps. A benefit that's unmatched by the nice leather ones: it's washable!
For heavier cameras I ended up with an assortment of A&A cloth and OP/TECH Envy straps. All washable and breath well in the humid, scorching weather that's coming to my area very soon.
Great too know my short and poorly filmed video make sense. I've not done it before, had to shoot and edit it on my iPhone.
I believe the CL has the same design too, even the same design of case. Hope the video can help others make their decisions to get the OEM strap/case or not.
They both are really great cameras, it's sad that they have such bad reputation and most people shy away from them before even give them a try(actually shoot them for a couple of days). M5 was actually my first Leica, and I'm so glad I decided to go against others recommendations.
I have used an M4 my father in law has and when I was able to handle the M5 I was like "WOW! I love this viewfinder!" I also like the "brutalist" design and the all black version. Through the lens lightmeter is also a nice to have. Problem is very few can fix the darn thing.
