pechelman
resu deretsiger
Thanks to the mods for moving this to the apparently appropriate place. My original intent was this for to be a discussion specifically related to using a monocrhom camera and migrating away from secondary software. I can see how this would relate to some other cameras, but without color information, I thought it was unique enough to be placed there, but no worries.
Short update on this topic.
I did some reading about lightroom and dehaze and found that my standalone version actually sort of does support dehaze through a bug of sorts. I tried both of the following 2 options, the first being more of a plug-in and the second being preset based;
https://cutthruthefog.wordpress.com/lightroom-6-dehaze/
http://www.proloststore.com/products/dehaze
I prefer the prolost preset based one just because it's simpler to use and quickly see the effect in the preview window.
Anyway, the dehaze didnt quite have the effect I thought it might, or rather it was more subtle in adding in some midtone contrast i was expecting and much more heavy handed in almost what appeared to be a global decrease in exposure that i was not expecting. It certainly got me closer to SEP2, but still not there. A dehaze of around ~20 seems to be about the most I generally add. For removing actual haze, it works OK.
After tinkering a bit more with SEP2, I'm now fairly convinced that lightroom cannot get there. The "amplify" algorithm for whites and blacks is really the trick here and the missing piece. What's more interesting is that now that I've been playing more with this, and recognizing the differences between the output from each workflow, I can now more quickly pick and choose which method to use to get the results I want.
I think I have my lightroom preset fairly well dialed to replicate the general look as far as tonal range and distribution, contrast, and such, so I think that my results from either workflow still have a reasonably consistent look and feel. Really, that's about ~70% of what I was going for here, so I feel mostly successful here.
I'm not giving up just yet, I'll still keep tinkering, but I think I may have progressed as far as I can at the moment.
My next goal is to get there with the color files from the m240. Feel like I'm getting close there as well.
Will keep this updated as I learn anything more. I encourage others to chime in if theyve gone through a similar learning process, even if, or rather, especially so, if their results\realizations are different from mine 🙂
