Leica LTM Summaron 28mm f/5.6 LTM
It may be etched into the retaining ring under the front element. I had a 35 3.5 Summaron and that’s where it was.
Serial number engraved at the rear, around the rear lens:
attachment.php
If the name ring of the Hektor says "F=50mm" it is an old one that was once fixed on a Leica I body that is converted now. The serial number is scratched inside, you can't see it if the lens is not disassembled.
If it says "f=5cm" it is a later interchangeble one.
Erik.
