Summaron 3.5cm/3.5 vigneting examples
The only photo that I notice vignetting in is in post #7 first photo upper left and right corners. Seems to be pretty mild. I have not used mine wide open but now that you mention this situation I think I will try it wide open and see. I have not noticed vignetting with the lens stopped down though.
Nikon Bob
Ronald M said:
I don`t see vignetting. In the self portrait, I see a shutter problem in that the pic gets darker towards the right. With the variable light in the first examples, you might mistake this for vignetting.
Photograph some eventoned subjects to check the shutter and vignetting.
Hi Ronald, in that room there is only one light source, a window, so the gradation of light you see might be of that. I didnt quite found any shutter problem on other photos i taken with this camera (although havent taken many because it is "new" eheheh).
Please post your tests with full open wide Summaron if you can 🙂 Thanks for helping me out here ehe I am giving you too much work 🙂
Sergio
