Summicron 35mm f/2 v4: overpriced and overrated? Prove otherwise with Photos please.
And now you know it was worth it?
Well, current V4 prices make what I spent seem a bit less insane.
Images from the V4 have been terrific. But I'd guess that I could have nabbed most of them with a CV 35/2.5, for a lot less money and not too much difference in result. I also had a 35/2.5 Summarit that I bought for well under the V4 price; it was pretty darned good, too.
Still, I'm not about to sell my V4 just yet.
I don't understand how it got the title of 'bokeh king' with bright highlights like that. Reminds me of the 40 summicron-c, very busy backgrounds if you have really bright highlights in it. (I mean those bright edges of the highlights) If you want really smooth bokeh those highlights should be very even.. like those 200mm shots demonstrate.
So, overpriced? I think so... either the 40 summicron-c is a huge bargain, or that 35 summicron is very overpriced.
It got its bokeh king title because of the rendering at F4 apparently. Not wide open shots which are often quite curly. But people use it mostly at F2 for bokeh ... 🙄
This being said, you are right, the 40mm Cron is an amazing and way undervalued lens.
I think the discussion about value is not clear enough.
The market value is the market value. The value you get when you use it has nothing to do with market value.
Is a german v.IV more usable than a candian v.IV?
I had lots of 35's in M-mount, and the 35 Summicron wasn't the "best" in any category except ergonomics. It's just the perfect size with a perfect tab and perfect handling. It's not great wide-open by modern standards, but it's not a special-effects lens like the 35 pre-asph Summilux, either. It's an excellent all-around lens that's perfectly suited to rangefinder photography.
Playing devil's advocate for a moment, I have to point out that a VC 35/1.2 35/2.5 combo can be had for less than a used Summicron V4, and they definitely offer a wider gamut of optical performance. 🙂
I've never used a 35mm Sumilux. What's a "special-effects lens"?
After missing a 35mm Summicron v. 3 on this Forum TWICE (same lens-slow to act), I opted for the 35mm UC-Hexanon. For Leitz prices, they should build lenses as Konica did. I couldn't be happier.
yeah 35mm and 200mm are different uses. heres some with 35 f1.4 L which i think have better bokeh.
^ People that didn't get my last post.. I didn't compare the nikkor 200 with the 35 summicron.. of course that would be stupid. What I did do was try to explain that the 'bokeh balls' in the 200mm look very uniform, they don't have those very bright edges that are visible in the photos taken with the 35 cron. THAT is what I tried to explain as causing busy busy backgrounds, because those highlights don't blend into eachother nicely.. instead you get a bunch of rings.
And I compared it with the 40 summicron (and m-rokkor btw) because that lens has the same effect, as can be seen in this image (which really pushes that effect):
Whoever thinks the v4 Summicron is all about beautiful OOF balls at close focus wide open should read Mike Johnston's original article on the subject
http://theonlinephotographer.typepad.com/files/bokehrankings5.pdf
He gives the Summicron a 10/10, but closed down (f5.6?) and at longer focus distances, and says "Worsens considerably as focus gets closer and apertures get wider".
In my experience, there are many other 35s with better bokeh wide open, for example the CV 35/2.5, the UC Hexanon, etc.
But like Kevin said, the v4 is the perfect size, and nice to handle. The v3 just as much, IMO. And I wouldn't buy a v4 for a used price that is very close to the used price of a 35/2 ASPH these days.
Roland.
Fully agree with this statement. I've recently switch from the cron to. ZM c Biogon. That extra stop that was never quite sharp enough is not missed. The lens is fantastic and IMHO has equal ergonomics, better build and better overall IQ for less money NEW.
Ironic to post a shot that misses focus when discussing sharp 🙂
I much prefer my V3 summicron to the Biogon-C. Its smaller, faster and the ergonomics are awesome (I hate the focusing nipple and the 1/3 stops!). Also in my testing although the Biogon-C is slightly sharper at 2.8, by F4 the differences are all gone. And, of course, the Summicron wins in both bokeh and sharpness @ F2.
I never liked my 35mm asph cron and prefer the type IV.
I love the unpredictable, sometimes Noctilux like bokeh of the type IV wide open.
Yes... the asph is probably sharper wide open but I can only laugh when people state the type IV is not sharp enough at f2.0.
This whole discussion comes dow to wether you prefer the drawing of classical Mandler designed Leica lenses or the modern Zeiss/ Leica lenses.
