Godfrey
somewhat colored
Take any lens and any camera raw and run it through raw SW that opens the fiel as it is without any corrections.
For example I use Raw Photo Processor on Mac (SW is Mac only, freeware).
Sony A7 raw when open as it is, without HEAVY in camera processing, is a raw fun![]()
Usually under exposed, everything way off.. The flange distance is just too short. If you look at the lens via "pure" raw, the FE 35mm 2.8 and FE 55mm 1.8 are joke of the lens, unperfect in everything.
So I dont think that it is Leica to blame, it is the only way to go with short flange distance..
The short mount registration has nothing whatever to do with lens aberrations.
The reason these lenses have so many aberrations is that they are being designed to be compact, light weight, and inexpensive to manufacture as the first priority, and for the reasons as Roger Hicks and I posted previously in this same thread.
Once a lens designer starts to assume lens correction in software after capture, there's a whole host of things they can do in the optics (that make the overall system work better, cost less, and be more compact) without having to worry about the simple corrections that software can take care of perfectly. Only a stupid lens designer would not be overjoyed to have the additional freedom that post-capture software correction permits.
G
Roger Hicks
Dear Godfrey,Exactly.
Correcting simple spherical barrel distortion and light fall-off in the corners (not vignetting ... for the pedant in me) are two of the easiest, least-lossy corrections you can make, while fixing longitudinal chromatic aberration, mustache or waved-shaped rectilinear distortion, astigmatism, coma, etc, are FAR more difficult.
Just like in many other locked-loop auto-correction feedback systems, you leave in the simple aberrations while fixing the near-impossible ones because it improves the overall quality of the imaging system. These lenses will only ever be used on the camera(s) for which they are designed, so it is only the total system that matters.
It's a wonder that all these "Leica enthusiasts" and "professional reviewers" are unwilling to give Leica the benefit of the doubt and believe that they know what they're doing with respect to imaging systems and quality, look at the results rather than infer absurd things from marketing statements.
G
Highlight 1: For a given definition of "vignetting".
Highlight 2: As I've said before, Leica should hand the business over to the "experts" on the camera forums who all know FAR more about optics, sensor design, software, marketing, etc., than ANYONE who's been in the business for a few decades.
Addendum, based on your most recent post:there are very few stupid professional lens designers, but plenty of amateur "experts" in design, marketing, engineering... It would be interesting to see how many people with genuine expertise in anything would react to the kind of ill-informed advice in their own field that is routinely dispensed on the internet.
R,
Emile de Leon
That's a lot of moola to spend on a lens that only works ok on 1 type of camera..
Scrambler
Dear Godfrey,
R,
As a doctor I routinely deal with ill-informed internet advice (and advice from friends, and pseudoprofessionals). It needs to be handled with tact and reality needs to be framed to agree as closely as possible with the misinformation. Humans don't change their assumptions easily.
As for the 'debacle', no one has suggested that the T lenses should be without software correction. What has been suggested is that the standard Leica briefing suggests that there are no software corrections when that is wrong and would have been a foolish move on Leica's part if they had gone down that road.
I wonder how many people consider the optical performance of their own eyes? Eyes are heavily distorted and have extremely poor definition except for one small area. It is all corrected in post processing.
Godfrey
somewhat colored
A Hasselblad SWC was an expensive lens too ...
G
Godfrey
somewhat colored
..What has been suggested is that the standard Leica briefing suggests that there are no software corrections when that is wrong and would have been a foolish move on Leica's part if they had gone down that road. ...
... If it was actually their error in the first place. So far, all the discussion of this "debacle" seems to stem from the reportage of one source, DPR.
G
Ken Ford
Refuses to suffer fools
Exactly why I passed on buying a Sony / Zeiss E mount 24 for my NEX-7.
Emile de Leon
You're funny..A Hasselblad SWC was an expensive lens too
Godfrey
somewhat colored
You're funny..
Thank you. I feel that humor is important in civil discourse. ;-)
G
Duane Pandorf
Last time I checked no one here has been forced to buy one of these yet. So what's the problem?
And I bet the majority of those that do plan on buying this kit have never heard of DP Review.
Roger Hicks
Which must be a bit of a strain at times. Those who know or understand least are often the most strident in propagating their misconceptions. A certain type of Zonie springs to mind.As a doctor I routinely deal with ill-informed internet advice (and advice from friends, and pseudoprofessionals). It needs to be handled with tact and reality needs to be framed to agree as closely as possible with the misinformation. Humans don't change their assumptions easily. . .
I have long said, "Never trust anyone whose vocabulary does not include the phrase, I could be wrong."
Aristophanes
http://newsroom.cisco.com/release/1128065
Many other studies back this up.
I would not assume that those who can afford it will not do their diligence.
willie_901
Due diligence is the luxury brand's worst enemy.
