T to M adapter?
WoolenMammoth
7:48 PM
Forgive me if this has been covered, I did a little searching and couldnt turn anything up...
Is there an adapter that allows you to mount a contax T lens to a M mount rangefinder coupled?
I would like such a device.
do you mean the lenses for the G1 and G2 series? Those are usually referenced as G mount lenses, though they are called the Sonnar T, for instance.
No, I don't believe there is any way to mount these on an M, especially not with RF coupling.
If you mean a generic T-Mount to M, you can.
First you need a T-Mount to Leica Screw M39 adapter. eBay has them. Then use a M mount adapter. I've done this to use an old T-Mount 28mm lens on a M4-P. Not really usefull as there is no RF coupling but it can be done.
