Tale of Five Films
swifty63
Fiat lux
1:25 AM
I just got back from a trip through the deserts of Egypt, Ethiopia and Djibouti as part of my work. Of course, I was keen to take some photos, which I have now developed and scanned. I took five different film types, and souped them all up in Ilfosol 3 when I got back. For some reason I was under the impression that Ilfosol 3 wasn't the best for the faster film, but they seem to have come out OK. At least they looked about as good as my own results from ID-11 and D-76 that I had used previously on Tri-X.
Anyway, I was interested again to see the difference in the grain with these differing speeds. Below is an example typical of what I saw for each of the film types. I used 120 film in a Mamiya 6, with yellow or orange filter. Scanned on Epson V750, minimal touching up in PS. From slow to fast:
Eastern Desert, Egypt. Pan F. Orange filter. No discernable grain in this one.
TMax 100. Northern Afar, Ethiopia. No grain here, nice fine tones in the foreground reeds. Only thing about the desert here is the haze, so the distant views aren't always sharp.
Delta 100. Eastern Desert, Egypt. Fine grain, I think Delta 100 gives me a bit more "zing" than Tmax - you may think differently! Actually I find them pretty similar, and like them both.
Here's the fast ones.
Delta 400. Eastern Desert, Egypt. Actually my first shot at Delta 400.
And finally Tri-X. Afar Region, Ethiopia. I also like this film!
I wasn't able to pick a favourite film from the five - so I will continue to use them all, depending on how I feel. Cheers, Swifty.
120 film? Grain? None that has ever bothered me. If I want a little grain with 120 film I shoot Delta 3200.
Very nice work. I'm jealous. I want to see some desserts.
Wayne
Thanks for the comments! Here's an example where the grain is more pronounced, from the same batch of Delta 400. It works well for me, I don't mind the grain.
Getting grain that noticeable from a 400 speed film when shooting 120 points to a development issue more than the graininess of the film, unless that is a fairly serious crop. Not that it is bad, mind you- I like the look.
I can't get grain like that with 120 Delta 3200 & Xtol 1:3. That photo, which I also agree is fine, looks more like my 35mm Tmax p3200 in Rodinal.
Wayne
