Test Photos from my deck with x100
hausen
10:55 PM
Hello all,
Had a little play this afternoon with my new X100. Stood on my deck and took a couple of shots that were tricky for the camera to meter. Set camera to Monochrome with Red filter. Used spot meter to pick a neutral zone, held down AEL button and took the shot. Uploaded to Silkypix (Use PC not Mac) converted to .tiff and imported into LR. Adjusted exposure down a little, sharpened and not much more. Then printed the file on my Canon 9500II and was very quite happy with the overall sharpness of the result. This is just the view from my deck and I snapped a couple to post here, didn't try to make it perfect it was just a test. Am pretty happy with the allround usability, and probably will be using it mainly for B&W camera that I can have with me all the time, and I think it is well suited for that. :D
Those look good.
You lucky bugger ... Im still at least ten days away! :( :D
I plan to use mine mainly for black and white and although Silky Pix is copping a bit of a hammering I'll be using it like you to create tifs and then PP'ing the files in my chosen software which is ACDSee Pro. One thing that I like about the Fuji is the inbuilt three stop ND filter which will allow high ISO shooting in fairly bright light at f2. I've discovered with my D700 that NEF's shot at 6400 convert nicely to black and white with the slight noise giving a slightly dirty look ... not like film grain but different enough to that very clean look that converted digi files seem to have.
Have fun! :D
@hausen
Same for me, it will replace my (rather my dad's) Minolta Himatic 7. Please keep us posted on your observations as you shoot some more. Thanks.
One thing I didn't realist about the ND filter is it's an on or off deal, as in ON it's 3 stops of ND and off it's off.
I thought I could select ND1, ND2 and ND3 as appropriate, but you can't it's just on (3nd) or off.
That is probably dictated by the fact that its a physical ND filter, not a software correction. So its either in an off / on stage. Multiple stops would require multiple physical filters...
That makes sense; none the less I had just assumed one would have a choice of ND level. Even so, it's a great feature to have.
related to filters... whats the best way to use a polarizer on the X100 or rangefinders in general?
The X100's EVF will show the effect of a polarized filter in real time. The OVF won't. However once the polarization is optimized, the OVF can be used even though the effect can not be seen. To attach the filter you will need the X100 lens hood attachment which contains an adapter ring; or the optional X100 filter adapter ring; or make your own adapter by gluing two third-party filter adapters together; or wait for a third party to make a cheap knock off of the X100 filter adapter.
For rangefinders without EVFs, you have to adjust the filter for maximum polarization when it is off of the camera. Of course it is trivial to attach the filter to the lens. I haven't used a polarized filter on a RF camera for some time. But I'm sure someone will share a detailed method shortly.
Thanks for your succinct answer Willie.
Great, the EVF then has an important role to play for the landscape photographer. I cannot imagine doing landscapes without a polarizer.
Perhaps someone else can tell me how people with rangefinders managed in the good old days without an EVF? A history lesson... anyone?
In the "good old days" you used polarizers that were viewable through the viewfinder. Either like this: http://www.leicagoodies.com/steps.html, or using a "swing-out" polarizer like #13352.
But I disagree that polarizers are needed for landscapes, in particular in B+W.
Roland.
:D I should add that I didn't mean that to sound so troll-y. It's still sort of true, though. Going to great lengths to attach polarizing filters to a rangefinger VF to facilitate infinity-focus landscape photography feels like it's missing about six important points, to me.
Unless you have to schlepp your camera into the mountains, do landscapes while traveling, etc. Obviously, when all your photos are made in ten meter max. distance from your truck (or Vespa, Keith), it don't matter so much.
But again, polarizers are mostly tools for color in landscape photography.
IMHO when using a polarizer for black-and-white film, reflections can be reduced, and it can lead to higher image contrast. Of course one can argue that using a red or a green filter will give almost similar results. However I have noticed that with monochrome using a polarizer gives a much more subtle effect than a color filter.
Isn't the simplest answer to rotate the filter on your Rangefinder and watch the meter as you do - when it gets to maximum effect (ie. lowest shutter speed or largest aperture) you'll know from the reading...if you go past that point it'll start getting brighter again, and your meter will indicate that as well.
Of course, on the X100 the EVF or rear LCD will be a much easier option; and of course with any digital camera, you can take as many test shots as you like to check the polariser's position.
R
