raduray
I’ve got a Canon 7 coming from Japan. Is there a way to test the shutter speeds?
Yes it’s definitely an option and I’ve done it that way myself but on older cameras shot-to-shot variation is also something that can occur. Also sensor width plays a part and can make a shutter seem slower than it is when testing faster speeds. It’s really great for leaf shutters though.I understand, but you can do 2 measurements in 2 different places of the focal plane, you should have an average shutter time, right?
I tried it on my rangefinders too (m3-m2-m4-mp) and the two cameras just CLA'd were ok (like 1/230 instead 1/250 for example), but the mp and m3 were very out of range (I didn't save the measurements but it was like 1/170 intead 1/250)
I use a Phochron XA but they are no longer available.I’ve got a Canon 7 coming from Japan. Is there a way to test the shutter speeds?
Yeah, shooting multiple aperture/speed combos for the same exposure was my first thought, but I was wondering if there was a way to measure the shutter speed directly.I use a Phochron XA but they are no longer available.
In the absence of any equipment find a scene with consistent lighting. Shoot a number of exposures at the equivalent exposure over a range of shutter speeds. When you develop the negatives they should all be the same exposure. If they aren't your shutter speed isn't consistent.
Ex: F16 1/30, F11 1/60. F8 1/125. F5.6 1/250, F4, 1/500, F2.8 1/1000
Then if something like the last shot is overexposed compared to the rest it tells you 1/1000 is running slow.
The higher end Samsungs (and maybe some others, but not iPhones I think) have a 960 fps burst mode . However it must be remembered that curtain speed is not a constant so gap width will increase as curtains accelerate. This will, as stated, be less of an issue at slower speeds.For slower speeds you could probably get away with using the slow motion video recording on an iPhone (or something else with a high frame rate) and record the shutter firing with a running stop watch in the frame too. When you are evaluating the shutter mark off somewhere that is the start/stop position for timing. That would likely work up to around 1/125 or so.
Higher than that would need higher frame rates to capture the shutter curtains.
I had to read this twice before I got it. very ingenuous.You can do a pretty accurate check. All you need is a digital camera.
Place the two cameras facing each other like the picture below. Open the back of the film camera, place a mobile phone showing a blank white screen and put brightness to the highest.
Now, set the digital camera to the shutter speed you want to test (i.e 1/60) set aperture to a random value (i.e. f2.8) and the film camera to "B". Press the shutter on the film camera to remain open and press the shutter button on the digital camera. This is the control picture, we know that the exposure is correct in this one.
Now set the digital camera to 4 sec and the film camera to the test speed (i.e. 1/60). Press the shutter on the digital camera and then the shutter on the film camera. This is the test picture.
Now compare the control picture to the test picture. If the test picture is brighter than the control picture, then your shutter runs slow. If it is darker than the film shutter runs faster than it should. If the test picture is darker on one side than the other, the shutters don't travel at the same speed.
Sometimes you can spot uneven exposure or capping at high speeds (1/500, 1/1000) by looking through the shutter at an even lit background. The method with the digital camera works quite well too. If you focus on the shutter plane, and reduce the brightness of the photo taken you can spot uneven exposure more easily.Is there a way to test the shutter speeds?
Try it a couple of times and you'll figure out how it works 👍I had to read this twice before I got it. very ingenuous.
