Garage Angles
Kiev 4A, Jupiter-8M (1969)
The 1950s J-8's that I've used have all been very good.
Steve, what kind of adapters do you use? The pictures look great.
Erik.
On the left is the Millennium-Nikkor, a Double Gauss design from the early 60's re-introduced with modern coatings in 2000. This is the gold standard of the Nikon RF system, known for its flat field of focus, and great performance. I have been really happy with it, but it definitely has a more modern look for portraits than a classic Sonnar lens.
On the right is the Nikkor-H•C 5cm f/2, a decendant of the Zeiss Sonnar, and one of Nikon's most popular designs from the rangefinder era. I believe they began designing it before the war, but couldn't source the right glass until 47 or 48...but Brian probably knows more of the history! It is incredibly small and great to walk around with, compared to the Millennium lens which is rather front-heavy on the Nikon rangefinders. The 5cm here is "propped up" by the black ring which secures the optical unit to the barrel, but when mounted on a camera, the difference is even larger. I know it is optically the same as the LTM version.
Many prefer the 5cm f/1.4 Nikkor SC (derivative/rival of the faster Zeiss f/1.5 Sonnar), but personally I like the f/2 lens for its smaller size and slightly less glowy wide open performance.
I had to take it apart myself to wipe oil from the aperture blades and do a general clean. Fortunately this is a pretty easy process! I will post some more photos taken with my lens here soon. Great thread!
It should be noted that the Nikkor 5cm F2 was designed before WW-II, was designed in 1937. The lens was originally sold for the Hansa Canon. I've read multiple Internet Sites claim that Nikon designed the lenses after the patents were invalidated after WW-II- but this is not true. The Nikkor is a different focal length from the Zeiss lens, it is not an exact copy- it uses the same 7elements in 3 groups, 1-3-3 layout. The individual elements are different prescriptions.
The Nikkor 5cm F2 is hard-coated, my 1948 collapsible Nikkor 5cm F2 looked like wax paper when bought, haze on each side of the aperture, It cleaned up perfectly. The Zeiss "T" lenses from the late 1930s and 1940s also are hard-coated on the outer surfaces: I've seen a mix of coatings used on inner surfaces. The Leica lenses originally had soft lens coatings.
