The 907x Has Landed ...
One of the exposures I made with the 500CM, digital back, and Distagon 50mm lens. It was hand-held and the light was poor so there's a touch of motion blur in it, but I like the look of it. Wide open, I believe, at ISO 1600.
Breakfast Potential — Santa Clara 2020
Hasselblad 500CM + CFVII 50c + Distagon 50mm f/3.5 T*
enjoy! G
INDEED! The Makro-Planar CF 120mm f/4 T* lens is just superb!
Yet another from my shooting around the condo.
Bananas – Santa Clara 2020
Hasselblad 500CM + CFVII 50c + Distagon 50mm f/4 T*
For me, this lens really does require the split image focusing screen for best focusing results.
enjoy!
G
My new ride ...
Living Room Art – Santa Clara 2020
Hasselblad 907x + XCD 21mm f/4
ISO 200 @ f/4 @ 1/3 second
:D
enjoy, G
No matter where you go, go there on two wheels.
The 907X is just a frame with electronic contacts to connect the digital back to the lens. The digital back is the CFV II 50C. It can be attached to the back of a 500-series camera, or it can use XCD lenses via the 907X.
Can it be purchased separate from the camera? I did a quick search the other day and couldn't find any information.
The CFVII 50c back and the standard 907x body will both be available as individual purchases soon.
G
Thanks, I really don't know why I asked, I doubt that I'll be able to swing it after buying the GFX but hope springs eternal......
I may be stuck at home due to the "Covid-19 House Arrest" ordinances now in place, but the Irish bears came out to celebrate ...
Happy St Paddy's day! :D
Irish Bears - Santa Clara 2020
Hasselblad 500CM + CFVII 50c + Makro-Planar 120mm f/4
enjoy!
G
Holy Jezzis with Forearms like that.....I’ll bet you can crack open coconuts!!!! Be careful you don’t crush your 11000$ ....camera....
A near-full-frame image:
Painted Tins - Santa Clara 2020
enjoy!
G
Thank you!
I ordered the Hasselblad 907x Special Edition set shortly after they were announced in mid-Summer 2019. The one native lens I ordered with it is the XCD 21mm, to net an "all digital Hasselblad SWC" in square crop, and I will buy another one or two X system lenses for it (already have the 45P on order...).
But ... I have the Fotodiox Pro adapters for both M and R mounts, and I wondered yesterday what a couple of those lenses might perform like on the Hassy's 33x44 mm sensor.
So I pulled out two of my extreme wides for the R system and then both my ultra-ultra wide 10mm for the M as well as the 43mm wide-normal. Here are some results.
In each of these panels, the top row is the XCD 21mm as reference. The left column is the full frame rendering; the right column is a square crop to the maximum image area where no vignetting occurs. All exposures at ISO 800 and f/8, shutter speed jiggered around to get commensurate exposure per frame, and processed in LR to make exposures close as I can (quickly). Subject to camera distance in all cases is ~4.2 feet.
R Mount - I tried the Elmarit-R 19mm f/2.8 v1 and the Super-Elmar-R 15mm f/3.5. Given that the 19mm is only 2mm shorter than the XCD 21mm anyway, and vignettes, there's really no point to using it in preference to the 21mm. The 15mm nets a useful additional amount of FoV. Both lenses, in their non-vignetted area of coverage, render very nicely.
M Mount - The two lenses I tried in this test are radically different, both from each other and from the XCD 21mm. And they're interesting: The Pentax-L 43mm, being essentially an SLR lens specially adapted to LTM/M-mount, vignettes only at the corners of the full frame. Cropped vertically, it's perfect. The Voigtländer HyperWide 10mm, an ultra-ultra-wide angle that just barely covers the format even on FF, shows this wonderful view that looks like you're looking out of the mouth of some toothy beast (yup, those are the little stubby bits of the rudimentary lens hood built into it...) in the full frame image. Cropped*square down to just within the hard vignetting, it shows substantially more FoV to work with than the XCD 21mm still. And at full resolution, it's a pretty darn good performer throughout. An impressive lens. :)
Higher resolution versions of these comparison grids are available by clicking through to Flickr.com on them.
I've also used the Macro-Elmarit-R 60mm, the Summicron-M 50mm, and the Elmar-R 180mm + 2x Extender-R on this camera. All three have done well, the 50 and 60 even on the full 33x44mm format, the long tele best when cropped to square.
enjoy!
G
Follow on to a prior post I made:
I experimented with test fitting the Leica M-mount Voigtländer HyperWide 10mm f/5.6 onto the Hasselblad 907x camera, using a Fotodiox Pro "M to X mount" adapter and the electronic shutter. Two exposures to compare: Both of these photos are made from identical camera position, 4.2 feet from the bicycle, at f/8 lens opening @ ISO 800. Exposure time (and post processing) compensated a little bit to make them render to about the same illumination.
First, for reference, a native, full-frame (33x44 mm sensor) shot with the Hasselblad XCD 21mm f/4 lens:
#1:
Simply cropping square nets the equivalent field of view of the classic Hasselblad SWC ultrawide camera (Zeiss Biogon 38mm f/4.5 T* lens):
#2:
The question I sought to answer was: How would the image differ if I adapted the almost absurdly short Voigtländer 10mm lens to the camera? Here's the full frame capture ...
#3:
... where you can see the rudimentary, tiny stubs of the lense's permanent, built-in lens shade poking into the top and sides of the image coverage. These obstructions are *just* outside the field of view with the lens fitted to a 35mm FF format camera. To me, it looks like I'm inside the mouth of some toothy creature…. :)
Next I cropped this image to a square that fitted just inside the hard vignetting obstructions at top and bottom:
#4:
This presents an "Ultra-SWC" square format FoV, with I'm guessing about 125° diagonal angle of view, a whopping ~30° more subject coverage on the diagonal than the SWC has! (For reference, the calculation is based on the diagonal AoV of a 38mm lens on 56x56 mm format vs what I'm estimating as 10mm lens on 28x28 mm cropped format.) What I'm most amazed at is that the detailing and rectilinear correction of this 10mm lens remains really good right out to the corners! Pretty fantastic performance.
Now to figure out what to do with all this insane field of view. :D
G
"If you're stuck in hell, you may as well roast some marshmallows."
