The end of IR filters??
pphuang
brain drain...
4:11 PM
http://www.dpreview.com/news/0809/08092401kodak_ccd.asp
The sensor also includes specific design features that optimize its use in the S2 camera, such as the use of microlenses to increase the overall light sensitivity of the device, enabling improved image quality under low light conditions. In addition, an infra-red absorbing optic was incorporated directly into the sensor’s packaging, enabling the development of a thinner camera design by eliminating the need to include this IR-absorbing function as a separate camera component.
Its just a matter of time! :D
Or just buy a 5D MkII and you'll never need IR filters again! :p
heh, thats a can of worms that did not need to be opened, that said I am completely sold on the 5D mark 2 and will have one for my pro work.
First people will embrace a filtered sensor, then turn around and put a UVa on their lenses. I don't get it.
if you worked in the conditions I worked in you sure would want to use a uv regardless if you missed 1% of your image quality...
Well, I understand completely. My point is why bemoan the requisite UV/IR filter when they'll just replace it with a UV anyway? I suppose the bemoaners just don't use filters at all.
IR is a M8 advantage.
I am inferred fan. Therefore, for me the M8 is the best off the shelf IR shooter produced.
I'd wager this is part of the "trickle down" technology to which Leica was referring when it announced the S2. Here's hoping it trickles past the R10 to the M-system.
I wish the future would sort itself out right now so that I could go ahead and buy a digital camera already without any more of this hemming and hawing.
