This may be age-related. When I was younger, yes, new kit inspired me. Now, the picture is what inspires me more, though I have to admit that sometimes trying to get ANYTHING out of new equipment inspires me.
I think it's related to
maturity in photography. Once you've climbed the learning curve on how to make images, then the image
should be what matters.
I'm not a Rhodes Scholar but I find a DSLR pretty simple to use and I would make sure I had all my settings correct well before taking a photo or series of photos in any situation. If you can convince yourself that a completely manual rangefinder will out perform a DSLR with matrix metering, focus tracking etc etc, good luck to you.
Slamming the SLR/DSLR has been a trend on this forum for as long as I've been here ... you're grist for the mill mate! 😀
I'm neither a Rhodes Scholar nor a luddite Keith, but I think that any camera I have to "tailor to my style" before I can start using it is over-done. I've had the DSLRs with matrix metering, focus tracking etc. etc. and while they're nice features, none of it is trustworthy when you need it most. Focus tracking isn't all it's cracked up to be (read any brand forum there) and matrix metering is fine, as long as its a "normal" scene. When you're outside of the design limits of "normal," and then you have to fight with the gear to use it manually, eventually it just gets tiresome. I've had a Fuji X-Pro1 miss focus on two out of three shots during a commercial shoot, all the while giving the glowing green focus confirmation light. And the X-Pro1 is all but useless in manual modes.
I have a Panny GX1 for snapshots and occasionally close-up live view and it does a nice job, but I'll take my M bodies any time. I'm trying something new (old) in the commercial business realm again and I just loaded up with late model "V" system Hassy gear. When I last owned Hassy, it was just Hasselblad, but now it appears to be Hasselblad "V" system to differentiate it from the Hasselblad-Fuji hybrids. Anyway, I'd forgotten how much I still "see" in square format, and it's nice how my hands fall to the controls so naturally. It's kind of like coming up for air and breathing again after holding your breath under water for a while.
When I did press photography, I copied the procedlure that I saw others use: take a reading on arrival, set the camera then forget the aperture and shutter, unless the lighting changed dramatically.
"f8 and be there."
Not too many years ago, one of our local hospitals was doing the first building implosion using explosives done in the state. I got there early and set up my new-to-me Olympus E3 on a monopod with a 50-200 lens (effective 100-400 on 4/3rds) with the motordrive on from the nosebleed seats behind the police lines a couple of blocks away. I metered, and set the shutter speed and aperture. With the first "puff" I pressed the release and got a nice, well exposed 25 shot string of exposures of the building's collapse. (yes I readily admit that my M9-P wouldn't have been as well suited to this task.)
The local paper had days to scout and set up four Canons set up with radio remotes in the best "strategic" locations around the building. They'd tested them and all was well, until
the moment. He triggered the remotes and got nothing. On any of the cameras. Testing afterwards showed them working fine. My guess was that the RF from the blasts interfered. They had no one "on the ground" shooting and got no images. I knew the hospital PR person, and they knew I'd been there, so my images made the front page.
The paper photographer was a (relative) youngster and was a child of the digital age. The lesson he learned was that the likelihood of the technology failing is directly proportional to the importance of the event. I've never had a manual body or lens fail during a wedding. I can't say that about AF lenses and electronic bodies.
So, the technology isn't always all it's cracked up to be. It's convenient under "normal" circumstances, but when you get outside it's design limits it can get really dicey, and that's not the time to have to fight with the gear to make it do what
you want it to do. The problem is that those limits aren't defined anywhere until you reach them and you have an unexpected failure. Sometimes knowing your stuff and using a manual process is more reliable when you HAVE to bring the images home.
