Biggles
My cup runneth amok.
Yes, sir, please do.
regit said:If anyone so willing, chipping in with the Noctilux would be most welcome 🙂
... Seriously BTW, am I allow to mention this lens in the forum??
ray_g said:Don't forget - use a tripod and a timed or cable release. As I pointed out, there are problems in standardization. But still, how many times have you looked at "sample photos?" 🙂
Brian Sweeney said:> test?
Raid: on the Sonnar's and others "adapted to or adopted by" the Leica's, it is necessary to test close and far focus.
HOW DID THE J-3 DO ON YOUR CAMERA!!!
I've currently got five J-3's in posession. I am going to try to get some time to test them for variation in sharpness/focal length. One kicked my butt for a long time, until I noticed the rear lens group was not correctly mounted into its collar. It was off by less than 1mm, but it really messed things up. That was on the 1950 lens made with German parts. Some do betters than others with focus drift once shimmed for close-up work, ie distant shots are more blurred on some lenses than on others. It's got to be the spacing of the elements and actual focal length of each lens.
Brian Sweeney said:Raid: in the three rolls that I shot with the lens, the focus was good with my Canon IIf and Canon 7. The lens took a filter, and the ring holding the front element unscrewed properly. I had to remount the aperture ring and focus collar to new positions after adjusting, and can understand if I got those off. How are you judging the barrel being crooked?thing surprises me on these FSU lenses any more. I had one J-3 that gave different distance readings to the same fixed point when used with two different Canon 7 bodies. The Canon 7's agreed on the distance when used with a Nikkor, Summarit, and Summitar. I finally found the Helical would not tightly screw into the mounting collar, and was getting pushed slightly out when used on the cameras. The lens mounted to a slightly different position on the two bodies. I ended up gluing it into place in its collar. Same lens with the rear module mis-mounted and helical re-assembled incorrectly..
FrankS said:Raid, the unequal extension is measured (by eye) from the aperture ring, right? What Brian was saying is that maybe the aperture ring was not installed perfectly parallel to the camera. The part of the lens that extends when you focus closer, is kept in place by the helical, which is part of the lens body, which cannot be crooked if it is seated on the camera body.
