The XA - Review & First Rolls
Darkhorse
pointed and shot
11:09 AM
Orange, CA
Yet another XA thread. And why not? It's a fascinating little camera. I received mine on Monday, and shot a roll on Wednesday with disastrous results. I managed to clean up the shots I liked, but I was somewhat put off by the experience as you can imagine.
It does take some time getting used to handling the camera. It is small and smooth, and it has a hair trigger. Mine came without a strap, and none of my camera straps fit the thing. So, I had to use a strap from a Wii remote. The rangefinder patch was, as you'd expect, faint. But it was usable.
My previous Olympus rangefinders all had better rangefinders. However, the SP was too big, and I didn't like how the RC handled out of focus areas... but I do miss that camera sometimes.
Composing was challenging. The image in the viewfinder can shift around if you're someone like me who wears glasses. Some of these shots were cropped a bit to adjust for that.
As far as the lens goes, it's respectable. Certainly not the sharpest lens there is. However, that's not to say it doesn't render interesting images. that it does. Plus it's plenty sharp for an ordinary print, or web image.
The following images were made with Kodak Ektar 100, and Ilford FP4 Plus. The FP4 was processed with HC110 in 74° for 6 mins. I wanted to use Rodinal but it was unavailable, I'll have to order it from Freestyle I guess.
Metering with this camera was OK. I think it did underexpose a couple of shots, such as above. But it was salvageable.
I'm not the best street shooter. Looking at this one above I totally could've made real use of the mirror on the right and remained inconspicuous to the two women in traditional garb.
All in all it's a respectable camera. As I've mentioned before, I'm planning to go to Paris for work in the near future and wanted to have a small all-film kit (since I already shot the city in digital). I'd have my OM1 loaded with Tri-X in 50mm and the XA loaded with Ektar for color, and wider shots. I think this may work out pretty well.
Thanks for posting. I've always wanted an XA and will probably pick one up. I held off because the I've heard the lens isn't the sharpest and I used to have "a thing" for min. f2 lenses on fixed lens rangefinders. But I have those needs met with other cameras. These pics are nice - especially the color, but they do look less sharp than I've seen, especially assuming that these were shot f5.6,8,11 as they're outdoors. Sharpness, to me, however, is somewhat overrated. Love the Ektar colors.
Do you find the camera genuinely, comfortably pocketable? The idea of a film RF that I can literally comfortably slip in my pocket loaded with some Tri-X is the appeal here over lens speed or sharpness... Appreciate, in advance, if you let me know before I spring for the $30 or so decent samples seem to go for used these days. Thanks in advance...
Even with little digital cameras, I seldom put them in a pocket. What I tend to look for in a tiny camera is something that I can walk around comfortably with in my hand with the wrist strap on. With my RC for instance it was heavier, and the lens cap came off easily. The clamshell design assuages my worries about the lens.
A few other observations:
- I think my metering problem was because of the sun, or bright light source hitting the meter from the side. If I shade the camera with my hand, the metering seems a bit better.
- The camera is more robust than I was expecting. I heard a lot of criticism over this, but it feels a lot more solid in my hands than I was expecting. Certainly more than, say, a Canon Digital Rebel. The plastic, though plastic it is, seems thick and strong.
- When I got the camera I thought, wow, it looks almost like a modern digital camera. I was not alone in this, my wife asked if it was a digital camera when she first saw it as well. Could this be detrimental to its alleged inconspicuousness?
- I feel kind of silly using the Wii strap. I think I'll need to order a new one from Gordy.
@Nick -- I often carry my XA around in a jeans pocket, and it slips easily into an interior jacket pocket. The lens can be a little soft wide open, and it vignettes, but it's quite sharp at f5.6-f.11 (at least mine is).
@Darkhorse: Nice photos, esp. 1, 2 and 4. I like using color film w/ more pop than Ektar in mine, like the old Kodak 400UC, or Portra 400VC, and I've also gotten nice results w/ Fuji Pro 800Z.
Nice, Dh.
Mine is actually very sharp at f5.6 and up.
If I remember right it measures > 60 lp/mm at higher f-stops.
I've been blessed to end up with an XA and XA4 for very little.
I found the XA rather underwhelming. Maybe the excitement for the camera messed up my expectations but I just wasn't happy with the results. I should shoot at least one more roll with it before parting ways but I just don't seem to click with it. Oddly, my sharpest shot with it felt like it was close to 1/15th or so. Maybe mine does better wide open but doesn't compare as well on brighter days? That doesn't make sense though.
http://www.flickr.com/photos/cannelbrae/sets/72157624508380851/
My experiences with the XA4 have been much more positive. I don't really know why to be honest - I like wide angle lenses but I don't normally do well with slow glass. Something about pocketable + wide works well for me. It also seems a touch sharper than my XA though I haven't taken any shots similar enough to be sure. I do know I average about 3 keepers per roll with the XA and closer to 10 with the XA4.
http://www.flickr.com/photos/cannelbrae/sets/72157624789517617/
As I prefer its lens at f/8, I use it prefocused at 8 feet only, and for direct sun only... I "installed" a precut piece of cardboard with the focusing lever space inside it, and after placing it around the lever place with the lever fix inside it, I made lever and cardboard piece an only piece with electrical tape above and below the lever+cardboard structure, so the lever just can't be moved in any way... After this solution I can open camera and just shoot it without taking care of the lever's position anymore: before this fixed focus system, the lever was sometimes moved away from 8 feet, even with camera closed, and sometimes while opening it quickly... I've used it prefocused since I got it... A true huge DOF 35mm lens on a point and shoot with NO shutter lag AT ALL, and no shutter sound... Lovely... Sunny Tri-X at 200 is her only food...
Juan
