Doug said:
Seems like the discussion's been mostly about Diafine as a sort of "zone system in a bottle", and a bit of emphasis on exposing for the shadows... This is all great, no put-down intended, but it isn't really the Zone System is it. I don't know that the Zone System is practical for roll film, except maybe with multiple rolls of film each in its own film back exposed in certain ways and destined for particular development.
Actually, in the gospel according to St. Ansel, you can, indeed, use the Zone System with roll film photography. I do it all the time.
Here are a couple of quotes:
Full control using the Zone System requires individual processing of each negative... It is a mistake, however, to assume the Zone System "does not work" with roll film cameras, since it is a practical expression of sensitometric principals, the Zone System remains valid, even though its use is somewhat different.~Ansel Adams
Adams was just reiterating the fact that the Zone System is merely a way to control contrast. Simple as that. From capture to print. Hence the following:
At the minimum, it can provide a framework for understanding exposure-development considerations, and making informed decisions that relate the circumstances of subject luminance and contrast with the capabilities of the photographic process ~ Ansel Adams {emphasis mine}
Next, he says:
With roll films we must usually accept the requirement for uniform development of the entire roll, and we can adjust our procedures to accommodate this fact ~Ansel Adams {emphasis mine}
Again, it is about control. You extend control over that which you are able to control. Then you just have to accept the limitations of the medium.
Next:
The absence of development control will mean a greater reliance on contrast control through the use of paper grades in printing. ~Ansel Adams
Adams goes on to say that one should use techniques (exposure and development) that enable the most information to be captured. He recommends exposure calculated to capture adequate shadow detail and to use N-1 development for scale compression.
Last:
We can usually achieve satisfactory prints {from roll film} this way provided we have taken care in exposure of the negative to be certain that detail is present throughout all important subject values. ~Ansel Adams {emphasis mine}
So, the Zone System can, indeed, be used with roll film capture. It is a way of quantifying exposure and printing to achieve what we "see" as the finished image. It ALL depends, of course, upon the amount of control we have at each step of the process. Control the capture, control the development and control the printing. Control EACH
to the extent the medium allows. This is what the Zone System boils down to in the final analysis anyway.
Tom
PS: I believe St. Ansel :angel: would have LOVED PhotoShop.
