David Goldfarb
I've got a couple of good zoom lenses and many prime lenses, and use prime lenses 95% of the time. The usual compromise with a zoom is the tradeoff between flatness of field and barrel/pincushion distortion--correct one and you lose the other, particularly at the extremes of the zoom range. They make some sense, though, for small formats, because you want to use every square mm of the frame when possible, and it's not always possible to stand where you want to stand.
So I use them mostly for event photography, where I'm photographing people and not usually as concerned about getting straight lines at the edge of the frame. I try to use short DOF to further minimize the importance of straight lines in the background.
They're both constant aperture lenses, so I can use manual or non-ttl auto flash with them.
I also use them sometimes with Super-8--there's no space to waste on that tiny frame, and cropping isn't an option for projected motion picture film.
