MartinP
Probably it is a good idea to read the instructions for the chemicals before using them too. Sounds silly, but 'assuming' times and temperatures and dilutions will eventually not work out.
So I've been UnderDeveloping it?
I can't see how not enough Developer would wipe everything out. I must be thinking about all this just backwards of how it really works. The Developer makes the image stick? So too little developer just wrecks things up a bit but it's not enough for anything to stick so it all just washes off??
Obviously it's late here and no light, so first thing in the morning I'll be outside shooting up this roll and developing at 1+7 with no Stop-Bath and I'll give the Fixer 3 minutes, then we'll go from there.
Thanks for all the help, I really couldn't do all this without you guys!!
J
I'm using Rollei High Speed Developer, cut to a 1+7 working solution as per the instructions on the bottle, then cut to 1+7 for developing time of 5 minutes.
Yes I was diluting to what the bottle said, which is 1+8 for the Working Solution. Then I was diluting for the 1+7 Developing. Can the film be wiped with not enough developer being used??
A completely clear developed film would first of all suggest that the film has not been exposed at all.
The situation with no margin imprints was not what I was thinking about, since I didn´t see the OP confirm whether or not these were present or not. I checked again now, and the OP indeed mentions in an earlier post that the margin imprints are missing.I'd interpret "completely clear" as "not even showing margin imprints" - and unless the factory had a major screw-up as well, that must be due to processing.
Well done 🙂 It is easy to get discouraged but instead you have done some never-to-be-forgotten learning! Like I wrote earlier, almost everyone has made a development cock-up at some point 😉
