Thumb Up cause problems on your M8 or M9?
Use the thumbs up and do enjoy the enhanced grip it provides, for me anyway. The thumbs up that I use comes with a rubber pad between the metal and the camera. I have only had it off the camera once and did not notice any wear or rubbing. I personally think it is a nice piece of engineering that works quite well . . . . . and I do not own a flash . . . . .
Life is Grand!
Dan
Watch out. The next thing we'll learn is using a soft release can damage the shutter.
Actually, if you check with Sherry, Don or Youxin, you will learn that soft releases can bend the release shaft - and do so frequently. 🙂 Must be Leica's fault, too.
I got a Thumbup used from KEH to try...didn't really like it so much. Twice when I bent forward and then stood up it came back and thwacked me in the ribs, once it snagged on my sleeve as I reached for something and it yanked the strap very hard against my neck, and once it snagged on my camera bag while I was taking it out and almost pulled the M8 out of my hand. Great little gizmo for the non-klutzy I suppose, but was definitely an accident waiting to happen for me 🙁
exactly what i'm thinking, ruslan. i can use my pocketwizards. i will have less of a problem with parallax using external VFs too.
I have one and do like it. But I find I prefer to not have it on the camera. I like the feel of holding the camera without it. But I often use a wrist strap and don't have to worry about gripping.
Wouldn't be without it. The Thumbs up has produced no damage on my M8 after more than three years, none on the M9. On the M8, with its slippery covering, it's probably stopped me from dropping it while picking it up. Model 1 is positioned exactly where my thumb would fall with a film Leica wind lever in the "ready" position. I don't support the camera with it, rather it secures my hand position. No damage to the bodies. Tim Isaac has designed a wonderful piece of gear. Yes, it probably bruised my chest a couple of times, but then so did Nikon F's years ago, and the wind lever on my M4.
