F
I agree i also adapted industar to be used on kiev and it is awesome!The Limited Edition Collapsible I-61L/D is really good.
View attachment 4840085View attachment 4840086
I have learned a long time ago to value my time, because asking for a refund has never worked so far.
The first 1.25 seconds were enough to understand the whole marketing ploy.
You really went on for the whole 10 minutes? 🤣
Wow, can you ever review a book in a hurry!
Thyphoc was enough…
"There is a principle which is a bar against all information, which is proof against all arguments and which can not fail to keep a man in everlasting ignorance-that principle is contempt prior to investigation."
--HERBERT SPENCER
You can tell Mr. Herbert Spencer that Mr. Ororaro has made the very, very, very best choice by sticking with Leica.
Thanks in advance.
Spencer was not speaking about Leicas. Humility is not making yourself small. Humility is becoming teachable.
Is this an easy mod or does it need real machining. Brians collapsible looks great @Sonnar Brian is this based on a pre-war Sonnar mount?I agree i also adapted industar to be used on kiev and it is awesome!
Thanks boojum, it seems a good lens at a good price. It would be a nice match for a Barnack except for the fact that it’s only in M mount as far as I can see 🙁
Yes- I have several collapsible mounts left over from converting 5cm F2 Sonnars to Leica mount. They will not fit a Jupiter-8 barrel.Is this an easy mod or does it need real machining. Brians collapsible looks great @Sonnar Brian is this based on a pre-war Sonnar mount?
Thanks Brian, this may be a winter day experiment ! I seem to have built up a few collapsible Sonnars with bad front elements so it may be worth sacrificing one.Yes- I have several collapsible mounts left over from converting 5cm F2 Sonnars to Leica mount. They will not fit a Jupiter-8 barrel.
This is an easy fit, no real machining required. You must grind down the aperture ring, but a file and sand paper does the trick.
