summaron
the noctilux is gimmicky and calls too much attention to its quirkiness. it gets boring after a while.
Not gimmicky, but a little samey and restricting.
Harry Lime said:I sold my Noct and bought a pre-asph Lux. This was before the Lux ASPH was available. Here's why I sold it.
- It's big by Leica M standards. It feels like you are running around with a 2/90 Summicron mounted. It's heavy. A Noct weighs about as much as the M body.
Both versions of the Lux are featherweights compared to the Noct, especially the pre-ASPH Lux.
- The focus throw is very long, which can make it difficult to follow action. The throw on the Lux is very short and crisp.
- The Noct will focus to 1 meter. The Lux will go as close as .7 m (70cm), which opens up a lot of possibilities.
- At f1 and focused at 1 meter you get about 1cm (1/2 inch) of DOF that is in focus. Forget about shooting anything but a static subject under these circumstances. DOF at f1 increases the further away the subject is that you are focusing on. Basically I would save f1 for subjects that were further than 5 meters away, unless they were static.
- f1 is sharp. The sharpest f1 you will see this side of something out of a spy satellite, but it's not THAT sharp. Also since the DOF is so shallow at f1, everything but the focus point is a blur. Of course this can look really cool.
- At f1 the Noct shows heavy vignetting. It clears up to a reasonable level by f1.4.
- At f1.4 the pre-ASPH Lux was sharper. The ASPH Lux will do even better.
- When shooting close-up the floating element in the Lux ASPH will blow away both lenses and even a 2/50 Summicron.
- The front element of the Noct is huge, so you always want to use a hood. The collapsible hood doesn't offer much protection, because it is rather shallow and doesn't lock into place. I had the second incarnation of the Noct, with the clip on hood. It offered plenty of protection, but made the lens even bigger.
- The Noct may be the most flare proof piece of glass ever made. It simply doesn't flare. Period. I shot mine straight into a 25,000 watt movie light and it simply sucked up the photons and spit them out the other side. Erwin Puts claims that there is zero scatter as light travels through the Noct and hits the film. Basically that means that the only image forming light that reaches the film, comes from the scene. In other words you see no blooming around specular points etc. This makes for amazingly clear pictures as night. It also means that the images the Noct produces look rather 'sterile'. This was one of the biggest reasons why I sold the Noct. I like a little glow in my pictures. For the record the pre-ASPH Lux is extremely flare proof. The ASPH Lux is supposed to be as good as the Noct (they share the same glass types)
- I wasn't too crazy about the Noct bokeh. It can vary from extremely smooth to down right bizzare and distracting. The pre-ASPH Lux is renowned for producing some of the smoothest bokeh in any lens and it draws with an amazingly wide tonal scale. For black and white photography you would be hard pressed to find a better lens.
So, there it is. The Noctilux or "The Queen of the Night" as I like to call her, is an amazing and special lens. But I would not buy it as my daily shooter. The Lux is a better choice for that. If I had money to burn I would buy both and take the Lux out for selective work, but mine ended up spending a lot of time on the shelf.
HL
Tee hee... That was nice...
NB23 said:Me, I don't see any sense in owning a 2000$ 50mm lens if it's not going to give me something real special. I'd rather use an AI Nikkor 50 1.4 for 100$, and so what if it's a little bigger then a 'lux. It's not like I'm a scorbutic 25 pound male in need of food an dying of some cancer. Even my grandma can carry a camera all day. Any 35mm camera.
MadMan2k said:Try carrying around a 1-series Canon or nikon F series with a fast zoom tele mounted (2 pound body, 3-4 pound lens), and then try to say that any m-mount lens is big or heavy...
The major one is missing - it is a challenge to use really well. You need to work at it. Most people are impatient and don't want to put the time in on a lens that they're not going to use a lot anyway.MikeL said:There must be some reason so many people sell their noctilux after the 'honeymoon' period. Weight, focus throw, frequency of using/needing f1, and the noct look (swirly-funky) are just not worth it for many.
Harry Lime said:The Noct on my M7 with Leicavit probably weighed as much or more than my Canon 1-v with a 50 or 35. The Noct defeated the whole purpose of having the compact M in the first place.
Stephanie Brim said:A Noctilux doesn't defeat the purpose of having a rangefinder...at least in my opinion. The reason I gravitated toward rangefinders was my dislike of flash and my desire to have a camera that was quieter. The dislike of flash prompts me to look for fast lenses, no matter the size. Even with my SLRs I never use flash. Fast, to me, is king. So, in my world, the Noctilux is pretty close to a perfect lens.
To each his own.
HL
Harry Lime said:I sold my Noct and bought a pre-asph Lux. This was before the Lux ASPH was available. Here's why I sold it....mine ended up spending a lot of time on the shelf.
