R
ruben
Guest
Today I disassembled the Kiev lower drum of the curtains compound, which is the one including the springs, whose tension determine most of the softness of the whole shutter action, and the softness of our cameras.
A photo of this part can be seen at Henry Sherer's site:
http://www.zeisscamera.com/Contax/Tech2.html#Shutter Tension
just above the title "The Propper Lubricants". BTW what you are seeing there is not the whole drum, but the inner part after another surrounding drum was already disassembled. This later outer drum is the one to which the curtain is engaged.
For this I used my first purchased Kiev, which since long ago is just a parts Kiev, and since short ago it is rather some remaining parts from and ex-Kiev. In order to extract this lower drum, I didn't studied the right proceeding and instead went to a plain crude use of scissors, hammer and force. At the Kiev project we are not going to fiddle at all with this part, but just clean, lubricate and re-adjust its tension.
My intention in today's disassembling was just to inspect this part to determine from the inside if my CLA of it, already performed on other of my Kievs, is reasonable or not.
My biggest surprise was.... Ok, now I get bets from you: is it a stupid basic spring compound, or rather a sophysticated German piece of engineering ? Close your eyes for 30 seconds and bet..........
The answer is the first. It is an extremely stupid, basic, springs compound, with a central rod as it axis, two separated springs at each side of the rod, two aluminium drums covering it, leaving a central space of the rod free for a third spring, covered in its turn by the bigger outer drum to which the curtain is assembled. Mr Sherer's pic give us a false impression, but I am sure it was not his intention.
My conclusions:
a) The hard issue is not CLA of this part, provided we do not disassemble it. And we are not going to. We can deal with it for CLA.
b) My drum and its parts were fully entire and corrosion free. The camera is, was, a Kiev 1971. If any spring or drum was damaged, this would call for a repairman. Not for our level.
c) Perhaps very old Kievs may have there some corrosion, and in that case, if our CLA will not help, we will have to send the camera to repair for replacing parts As I said the hard issue is to engage this whole compound to the body chasis, the tapes and the curtain.
d) The CLA we are going to exercise MUST start from our clear assesment that the camera we are working on is not jammed, or broken. Or the contrary. The first milestone for this it the test I refered to at "The Kiev Project - Part 1". Once we will contrast this type of test to the same test we will perform after CLA, we will be able to determine about any Kiev if the camera just needed CLA or is broken and needs Repair. Or if it has been canibalized, in whose case we may or may not be able to restore it to propper work, according to what we have.
e) MOST of the chances with our stiff Kievs, and here I cannot speak on behalf of Cotaxes out of ignorancy, is that they are not jammed or broken at all, and our CLA will bring new life for them, and for us.
Ruben
PS
Kindly enable me to add another conclusion: Ignorancy is our wort enemy. Research our best friend.
My conclusions:
Ruben
PS
