Tuolumne
If you look at my earlier shots of the George Washington Bridge, I think you can even tell from the thumbnails which was shot on a 35mm and which on a 6x4.5 MF.
/T
/T
charjohncarter said:I tried to go through all of the posts to see if this was mentioned: David Vestal wrote in the the late sixties that one of the factors that effects tonal quality is the film base. He said that because 120 is paper backed, it is able to get away with a thinner film base. 35mm film has the base and the strength all in the film base (e.i. thicker). The 'new' 35mm films have much thinner bases but maybe they still are thicker enough to cause an increased diffusion and light absorption over 120 film. And therefore reducing tonal quality. I would not say this is the only reason for the tonal difference phenomenon, just another factor.
David Goldfarb said:Zeiss claimed that 220 produced sharper results than 120, because direct contact with the pressure plate resulted in superior film flatness.
charjohncarter said:Just a thought, take a 120 negative that has good tonality and a 35mm negative with good tonality (by your definition), then cut the 120 to the size on the 35mm negative and print it. See if you can see the difference.
RObert Budding said:It's also possible that, perhaps, they were trying to sell more of their 220 vacuum backs.
