Roger Hicks
Not entirely true. If you don't mind light and bulky, you can get very stable lightweight tripods. I have an MPP with 'crutch'-style legs (wood above, light alloy below) and no centre post. It weighs a kilo (2.2 lb), and it supports any reasonable 4x5 inch camera easily, though a full-house Gandolfi Variant Level 3 is right at the limit.I haven't got a french anectote at hand, but I also recommend the Gitzo traveller carbon - look if you find it second hand. No matter how much you will fool yourself, carbon tripods are the only ones that break the rule, that a light tripod is useless. In case of the Rollei, with the Rolleifix, the camera is easy to mount, and the weight is very well centered above the head of the tripod, moreover, if you are using the classic WLF, you do not need the tripod to be very high.
The drawback is that it's about 33 inches/84cm long when collapsed and 54 inches/137cm high fully extended. All figures (weight, length collapsed, height) exclude whatever head I choose to put on it.
Oh: and it cost me a tenner, call it $15, in the 1980s. That was complete with head. It was probably made in the late 1950s or early 1960s.
