teddy
Jose Morales
Considering you initially said that you were attracted to TRI-X for the charming grain, then XTOL would be the one developer that I would avoid with this film.
As others have mentioned, the formula of TRI-X has changed over the years so it no longer produces that mongrel grain that it was famous for when dunked in D76 1:1. If you want to reproduce that look of the original TRI-X then Rodinal would be the go to developer. However, you should expose it at EI:250 or 320 as you will struggle to get an EI:400 with Rodinal. If you are also using a medium yellow filter, then you will have to adjust your exposure again and open a stop to allow for the filter.
So, for hand held street, perhaps TRI-X and Rodinal would give you too low a shutter speed for images on the 'go' - of course depending on your technique.
So, I would recommend Ilford HP5 Plus with D76 1:1. You will be able to expose at EI:400 and will produce images that are similar to the original TRI-X in D76 1:1.
Yep, well I do prefer images with grain, and more tonality rather than CLEAN and high contrast. But I can appreciate this effect as some of you have shown and it has it's place. So in case of what you are saying, exposing at 250 with a yellow filter will give me say, more shadow detail than what box speed would?
