squirrel$$$bandit
Nice. How long does Diafine last once it's diluted? The main reason I favor HC-110 is that it's easy to use as a one-shot developer...my film use is very haphazard and I tend to let, say, D76 go stale.
OK, just did a little research on Diafine...holy moses. It seems kind of miraculous. As a lazy and impatient developer (and somebody who exclusively scans to digital) this seems like the stuff I need. I will get some.
Bingo. I seem to recall rating Tri-X at 1000 ISO with Diafine. Is that right?
Internet seems to agree that this is the sweet spot. I'm super excited. Live and learn!
I agree that Diafine is not for every film. It works very well with Tri-X, Plus-X, FP4+, and Fomapan 100. I've tried it with TMax 100 and the results were meh. I haven't tried iit with Double XX.
Diafine can work beautifully with low contrast scenes if you use a yellow filter. I often shoot Tri-X with a yellow filter and expose at 400 if I'm developing in Diafine; take the filter off and expose at 800 for indoors or low light.
You can re-use Diafine and it will last quite a long time, although dilution A will deplete because it's absorbed into the emulsion. I mix up a new batch when dilution B gets too loaded with sediment. It's a great developer for warm climates; in the summer, the water temp at my house in Sacramento is over 72 degrees, and I have to cool the chemistry down to 68 degrees F. With Diafine, the higher water temps don't matter.
With TMax and Fomapan 200, I use HC 110, which is a great all purpose developer. But Diafine is very useful with certain films.
Try Ilford DD-X, which is a bit more expensive. Tri-X is closer to ISO 640 in DD-X, with nice tight grain and well controlled highlights.
Caught by bingley0522, on Flickr
Bridesmaid by bingley0522, on Flickr
