Other/Uncategorized Triotar 4/13.5cm LTM
Other Screw mount bodies/lenses
Jacques M.
6:47 AM
Hello,
I have just bought a 4/13.5cm Triotar, in the 3214xx range, so delivered at the end of 1947, according to Thiele.
Not very common in LTM version, as far as I know. In fact, it was probably a M42 one originally. But in those days, who knows...
That lens seems coupled, which is surprising. I thought these Triotars were not... It seems it is the metallic piece which couples the lens to the rangefinder.
http://cgi.ebay.fr/ws/eBayISAPI.dll...eName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
If some of you have light about these lenses, thanks!
Jacques.
Looking at the eBay lens, I was thinking that it was either an M42 or Exakta mount lens that was modified for LTM.
I don't think that I would want to try to "guess focus" for a 135mm lens unless it was at or near infinity.
Used to have one in Praktina mount, 40mm. It looked identical to this one, except for the different-colored ring at the base, which was missing from that lens.
One thing's for sure, the Praktina mount lens had no RF coupling at all ;) I'd like to read if it focuses correctly on a Leica and how it draws once it arrives, Jacques!
I will tell you as soon as it arrives, Johan!
The seller verified it's a 39mm screw before I buy it. OK. But really I wonder how the coupling works...
Amitiés. Jacques.
I have received the lens this morning.
Very good surprise: the coupling seems made by the factory and it works perfectly on my Leica IIIg. As it seems by the rangefinder! And it is in a near mint condition.
I will try it in a while on this IIIg with a film. But coupling or not, I think this sort of lens is hardly usable on rangefinder cameras. It weighs near 500g and is more than 16cm long... and has no screw for a foot! The limit for a daily use is probably 90mm.
It will be perfect on my red curtain Leica IIIc.
Amitiés. Jacques.
