Uneven Frame Spacing R2A
dphotoguy
8:18 PM
Crazy LOS ANGELES
Hello Photogs,
After running several rolls of film through my 3 months old R2A, I started to notice some uneven frame spacing. The frames are not close to overlapping (yet!) but I would just like to know if this a known problem? Will I beable to fix this issue by myself? Any suggestions?
Thanks
My R2A has done the same thing on a couple of rolls. No overlap, just uneven. Maybe I'm dense (no, I AM dense), but I ignored it.
I don't know if this relates to your case or not, but did you know that frames shot with a super-wide lens sometimes look closer together than those shot with longer lenses? The light from the exit pupil of a super-wide hits the film at such a flat angle that it actually reaches a little farther back under the edges of the film gate!
I have this problem with my Nikon FM2 AFTER I dropped it. But I haven't this problem with my Bessa R2s (I have 2 R2s).
My R2 seems to have reasonably even spacing. What's not so ideal is that the spaces between frames always ends up in the middle of a sprocket hole.
