unixrevolution
It's been a few years since I have developed black and white film at home. In this case it'll be HP5 at 250 ASA, Ilford film developer and Ilford fixer.
It seems worth it to use distilled water to mix up the developer and the fixer concentrate to ostensibly help prevent dust/particulants settling on the negs. Is it worth it? Is this overkill, or should I just use regular tap water? Naturally I'll be using tap water to wash the film after fixing it, and then using distilled water with Photo-Flo before hanging the film to dry.
So what do you folks do? And what is this Ilford washing regimen that I've run across on RF Forum?
Thanks for your response!
Distilled water is so absurdly cheap compared to the cost of other chemicals, the cost of film, and the opportunity cost of going to take the photos, that I can't see cheaping out on this step if you're really worried. I would use it, at the VERY least, to mix up the developer. I would also say it should be the final rinse at the end, but I am terrible at practicing what I preach in this regard.
