Using Flash on M8
remphoto
11:58 PM
North Central Ohio
I know it is a sin to use a Leica M with a flash, but occasionally it is useful. Other than using a flash dedicated to a Leica is it possible to use a small generic flash (i.e., Vivitar 2500) with an M8 using a a flash hot-foot/PC adapter?
Be careful, older flashes have too high a voltage feedback, and the can cook the electronics on the Ds. I use CyberSychs for my DSLRs and also for all my older cameras (mostly to get the flash off the camera). Sometimes I use the unit on camera but these are SLRs from the 90s on.
It is certainly not a sin to use flash with a Leica!
However TTL flash is criminally poor on the M8 as the pre flash is nearly as bright as the main one. It also introduces some shutter lag. If one accepts that the TTL is not needed then you may as well choose any relatively modern flash. One with a bounce head is worth the effort. Check the weight on the M8 anything reasonably powerfull makes it feel very top heavy. I am also very impressed with off camera flash (as is 'Idea Dog') with a diffusor and you might think about exploring this option with a wireless transmitter. This leaves the camera nicely manouverable. If you have any other current camera sustem its as well to get a flash which is versatile. Metz certainly have some advantage via SCA adaptors.
Richard
I have a Nikon Sb 80 Dx which is very big for m8 but great lighting. Use auto. and have a Leica dedicated compact and small one very comfortable and precise results.😉
