Using Pentax S-M-C lenses (M42) at Spotmatic SP and Ricoh TLS 401
Thomas78
3:12 AM
Düren, Germany
Hello,
I have some of the Pentax S-M-C lenses (M42, the type for full aperture TTL metering).
Can I use them on a Spotmatic SP and a Ricoh TLS401 without damaging camera and/or lens and does the aperture work correctly while the camera takes the picture ?
IIRC all manual focus Pentax K lenses are fully back- and forward compatible, issues did not begin until AF.
The OP has m42 lenses and bodies, not K mount.
@OP:
There will be no problem using the S-M-C Takumars on earlier Pentax or other Pentax/Praktica m42 mount cameras. You will need to do stop-down metering with any such metered bodies even if those bodies supported there own full aperture metering (few did). When Asahi/Pentax added the full aperture meter coupling they made sure the lenses and bodies were both compatible with the earlier versions.
@OP:
yup, no problems. the 401 is a great great camera too, enjoy it!
tony
Thank you!
