V500 Scanning Problem
aaron.tam
5:24 AM
If you look closely at the right vertical third portion of the picture, you'll notice a blue/purple line going right through the scan:mad:. This was scanned with a V500, any ideas what this stripe is? Thanks.
I used to have a V500, and this happened fairly frequently with colour film (the line was usually a red/purple colour) and cleaning the glass would make it go away.
Hey, this is a 120mm scan. It's not a scratch on the neg, I've tested that, the line stays where it is when I look through a group of pictures from many rolls, it's even bigger when I scan 35mm. I want this stripe gone!
Cleaning the glass on both sides means opening the scanner up and cleaning the glass - carefully - like it was a large lens. Check your manual for instructions. While you're in there, using an air-bulb, I would blow any dust off the sensor and internal optics.
Using film and scanning it is like making the photograph twice. Except the second time is less fun. (But until that budget-priced RF with the 24x36mm sensor comes out, it's how I roll.)
I think it's dust on the sensor.
