versions of the 50mm Summicron
FrankS
Registered User
10:44 PM
Let's see if I have this right:
version #1 is the collapsible lens
#2 is the rigid
#3 is an untabbed lens
#4 is a tabbed lens
#5 is the current tabbed lens with built-in hood
also in there, but not given a separate version # is the DR, same as version #2 but with a diff focussing mount
Have I got it right? Can anyone direct me to a website that explains all this?
The current Summicron 50mm isn't tabbed is it? I wouldn't have bought it if it was. :confused:
#2 is the rigid
#4 is a tabbed lens
#1 Yes
#2 Yes, also shared the optical formula with the DR, which has a close focus mount and associated eyes. Modified optics from #1
#3 Yes, modified optics from #2
#4 Yes, modified optics from #3
#5 Untabbed, built-in hood, same optics as #4
Thank you, Mike! That's why I was checking. I did not have much knowledge of the newer Summicrons before. I only knew about the collapsible (which I've got) the rigid and the DR.
