chendayuan
Price reduced $450
Price reduced $450
In addition to above flaws, there is another flaw, the film to lens flage distance is incorrect, any lens wide than f4 will be soft, even you set the rangefinder correctly, do not blame the lens. the problem is due to someone has removed the lens mount in the past and never bother to put back the shim or washer under the lens mount.
due to this additional flaw, I will knock off another $100.
so $450, if you think the price is redicules, please make me an offer here.
Price reduced $450
chendayuan said:haha Frank, let me relist it for you if any taker we can split the profits
I have for sale an almost mint Canon VI-L (some small faint bright marks visible when tipped towards a light source) with its brown leather ever-ready case in very good shape. This model represents the zenith of Canon ....(delete few lines) Check out this model at the Canon Museum here: http://www.canon.com/camera-museum/camera/f_camera.
The camera has following flaws:
1. the shutter speeds of 1/30sec and 1/15sec become 1/4 sec and 1/2 sec. The faster speeds and the slower speeds are fine.
2. The viewfinder is clear and the rangefinder patch is contrasty and properly adjusted vertically and horizontally. except a small glass chip at the buttom of the viewfinder.
3. the shutter curtain has quiet a few dents and wrinkles on the second shutter curtain, as most do. Does not affect function. The first shutter curtain is Ok
4. there was a slipping problem with the winding mechanism, because the camera requires 2 strokes to cock the shutter while the back is open (and only a single stroke while advancing film when the back is closed.) The camera's function is 100% consistent however, at first I believe this is a design feature to facilitate film loading and advancing to the first frame but unfortunately it does not happen in my other Canon RF (P/VIL/7 et al), a call to Essex about this problem their answer is 1) the wind gear is strip or wear out 2) the clutch system is not working, a CLA will run $150 plus part labor to fix the winding problem. So I offer here to sell it $550 ($50 less than The Photo.net offer due to above probelms and you get a free case).
This camera is offered with a money back guarantee.
Any taker please drop me a line.
