back alley
IMAGES
the other day my 75mm cv finder arrived in the mail.
i quickly put it on the zeiss ikon to compare it the built in 85mm framelines.
man, what a difference.
walking up to a hanging 16x20 frame, the 85mm fl lined up perfectly with the top 2 corners of the frame. the external 75 mm finder swallowed the frame and then some. the difference was large and surprising as i thought it would be much closer.
this may help explain why i used the cv 75 so much more than i now use the hex 90. i think the zi 85 fl are much closer to the 90 fov than to 85.
