arthurq
I took the top of to clean a bit, and now the whole viewfinder exhibits a yellowed double image. the rangefinder patch still works, but I can't figure out what's causing the overall double image. you can see it to the left of the TV there.
thanks for any suggestions you may have.
Pompiere
I have a TLR that does that after I cleaned the silver off the front surface of the viewfinder mirror. The light is reflecting off both the front and back surfaces of the mirror glass, so there is a double image. The coating is pretty fragile, mine was oxidized so bad that it came off as soon as I touched it.
Keith
The Yashica Guy and a couple of other sites stress not to touch the mirrored surfaces in the rangefinder mechanism with anything at all ... that coating is very fragile apparently!
b1bmsgt
Yeah, I still use film...
It could be that the mirror coating is worn off, but I have found that it is much stronger than it has been described. I clean them with a breath and a Q Tip with no damage.
Does it sound as though anything might have come loose inthe viewfinder? That would be the other possibility...
Russ
Russ
