Vignetting nikkor 24 2.8
megido
1:47 AM
I'm experiencing strong vignetting from f8 down with an original 24mm 2.8 lens. I'm using a standard (jessops) 5mm thick filter and dedicated HN-1 hood. I'm wondering if the Nikon L37 filter will reduce the problem presuming it's thinner in depth. Any other users out there willing to share any experiences/solutions?
Many thanks
I've seen no vignetting with this lens and the HN-1 hood, but haven't used it with a filter yet. You may want to try it with a thinner filter, but some of them (like Hoya) might not have threads to attach the hood.
My environment is not conducive to having no filter and the front element is quite exposed without. Will try to find a thinner example. Any one know the correct pitch of the threads?
Any regular 52 mm filter will work - just less than 5mm thick. I've never had the problem you describe but then never used such a thick filter.
That's what I thought. It just happened to come attached with the lens. I'll try a thinner one. Any ideas on thread pitch?
I have noticed corner vignetting when shooting skies with a filter and the HN-1 hood. No vignetting with either the filter or the hood alone. All my quicks tests were done at f8 on a late model non-AI version, but it is the later NC multi-coated version. I believe all are the same optically.
Sent from my iPad using Tapatalk
5mm thick? That's enough to stop a bullet, including the one that tore through jim_jm's Leica!
That's actually a Nikon F, surprisingly they are not 100% bulletproof as some might believe.
Belonged to a Vietnam-era photojournalist, who sadly did not survive. His name escapes me at the moment...:(
Yes, mine is also a late NC with scalloped focus ring. I''m currently using it without the hood as a test.
My Nikkor 24/2.8, #572430, with a L1A filter on front and hood has never shown any of your problems that you talk about.
Overall depth measurement with thread: 6.24 mm
Ring depth without threaded portion: 3.77 mm
Also lots of times I use the Nikon Rubber Hood to, as it is shallow and 3 inch wide.
Thank you very much. It seems I need a La1 or similar then as my filter is 5mm without the thread.
Just to confirm, have you been using the Hn-1 hood with the La1?
There is no particular model / catalog number on Nikon filters. Just the color designation.
These filter rings seem to vary all over the place. I checked the odd collection of 52mm filters I have. The thinnest is a Petri with a 2.5mm thick ring, but no threads on the outside to accept a screw in hood. An unnamed Japanese filter at 4.4mm, but another one at 5.0mm. A Tiffen filter measured in at 5.5mm.
The thickest filter I could find at about this size is a Canon 55mm filter - 5.7mm.
