Voigtlander 75/2.5: M7 or Bessa R?
robert blu
quiet photographer
11:10 AM
Italy
I never used much my CV 75 /2,5 and plan to make some experience with it.
It should be about portraits in interior.
Should I mount it on my Bessa R or on the M7 (with adapter): planning to shoot full aperture, or anyway very open on which should it be easier to focus? I guess the m7, but not sure. Any opinion? Suggestions?
robert
robert
Wide open, it's not a very sharp lens, so I don't think "nailing the focus" is as important as getting the shot, and getting it well-framed.
What magnification is the M7?
Having single frame brightlines is a big plus in favor of the Bessa R.
Personally, I'd go with a Bessa R3A or a ZI (the cross between the inner breaks on the 50 frame provide concise framing for a 75).
I took some of my best portraits on film with that lens.
It's actually a very sharp lens even wide open, just don't use it at 0.9m focus distance (it shifts and is optimized for infinity - well, at least mine is - depends of course on your adapter, etc). 1m and up will be fine.
Which camera for portraits ? I would favor the M7, but I'm biased 🙂
Reference this post from Tom A. about a wide range of 75s, in which he says about the 75 Heliar:
"Heliar 75f2.5: small, compact and actually very good. Wide open it has slight softness - typical of the Heliar design. Not unsharp, just a softer look. Good travel lens as it will comfortably fit in a pocket. It is a screw-mount lens so you need to add an adapter. Usually can be had for $300 + adapter. Not a bad lens to start with if you want to try out 75 as a second lens."
http://www.rangefinderforum.com/forums/showpost.php?p=1413496&postcount=8
My recommendation would be for a Bessa R3, or a Leica 0.85x, however I have encountered substantial focus misalignment with my copy, so you would be well advised to mount the lens, and shoot some wide open shots of a focus target at a typical distance for portraits ( 1.3-1.5m) to see how it fares. It is one of the most beautiful RF portrait lenses on the market.
Thanks all for suggestions, of course first thing to do is to try myself! My M7 has the 0.58 VF but I have the 1.25 magnifier. The 75 frame line in the Bessa R would make it easier to compose, on other side I should also learn to compose on the M7 and the 50/75 lines.
If the lens has a kind of softness wide open could be good in a portrait, I think.
robert
