drewbarb
picnic like it's 1999
Has anyone heard inklings of this lens before this announcement?
https://www.dpreview.com/articles/1...-manual-focus-lenses-for-sony-e-mount?slide=7
I was always curious about the Leica 75mm f1.4 lens, but I've only shot a few frames with them. I know CV has produced at 75mm M lenses before, but I'm curious about this.
michaelwj
The problem that the older 75mm CVs have is their 0.9m MFD, it seems to be fixed in this one, going to 0.7m. It looks like it could be a winner.
alan davus
I haven't bought a new lens for 6-7 years despite the recent excellent offerings from CV but unless this 75mm is dog (doubtful), I'll be in the queue for it.
rfaspen
[insert pithy phrase here]
How much will this lens cost me? When/where can I purchase it?
Having dealt with my 35 and 21 desires (partially met by CV), I have a long standing interest in a 75mm for my environmental portraiture. I have been using a 50 and a 90 for these images, and its obvious to me that 75 would be great. I keep thinking I can plunk down for a Leica summarit (the 2.5 version is adequate, but the 2.4 would be better....because of the 0.7m focus vs 0.9 for the 2.5 version). This new CV lens is faster and focuses to 0.7m. So, now I need to know how much and where/when it is available...
Looks very good, probably will perform excellently... and that's a lot of glass!
peterm1
Call me superficial but deep down I am shallow. This is a gorgeous looking lens and if it's elements were made from old beer bottles I think I would still want one. Truth is I already own the 75mm f1.8. and like it very much except for its form factor- it is rather long and skinny. I know this should not make a difference and at one level it does not but like I said, deep down I am shallow. I guess most of us are to some extent which is why we prefer handsome looking cameras to a shoebox with a hole in one end and Leica M's to the Argus "brick". Well it's one reason.
Ko.Fe.
Lenses 35/21 Gears 46/20
Good they dropped this too retro focus ring.
Out to Lunch
Ventor
Wondering how hard/easy it will be to focus at 1.4.
michaelwj
Impossible, it’s an f/1.5!
Focusing a 75/1.5 will be the same as a 50/1.0. Really hard.
Out to Lunch
Ventor
Ah...in the original post it was announced at 1.4. Even at 1.5 it's going to be hard.
lynnb
Just how thin is the dof going to be at minimum focus distance wide open? 5mm? 10?
Graham Line
depth
depth
Yes, but think how striking it will look if you nail the focus?
depth
Rob-F
Likes Leicas
Maybe CV will introduce some new focal lengths for Leica M. A 17mm, 18mm or 19mm f/4.5 would give alternatives to present choices. Not that we've never seen these focal lengths before, just not in Leica mount. The 17mm setting of my 17-35mm Nikkor is very useful, but weighs a ton! Time for a small and handy ultrawide. I sold my 15mm CV in anticipation of getting the version 3. And I think I will.
Godfrey
somewhat colored
The Leica Tri-Elmar-M 16-18-21mm f/4 ASPH covers all of these and is quite compact. It's also a brilliant performer. But it costs a bit. I don't use mine enough. :angel:
Anyway, this new 75mm looks lovely. I hope it performs on par with its looks, and I wonder what the price is. I doubt I'll be buying one—I already have the superb Summarit-M 75mm f/2.4 and don't need a faster 75—but it's nice to see new lenses coming on the marker.
G
Teemō1
You can't get much more retro than manual focusing helioids. I've not found a solution for cleaning the deep grooves on old lenses so the half-smooth scalloped design is much more welcome.
quadtones
Looks like a good candidate for the addition of the Taab or the STEER.
I got to play with the new Nokton 75/1.5 at CP+ yesterday. Was really surprised at how light it was. Certainly does not feel like there are seven lens elements stuffed inside the barrel, even though there are. It also seems quite compact for such a fast 75mm lens. Would be an easy lens to carry around all day. Focus throw also seemed fairly short, albeit precise. Certainly a nice option if the 75mm focal length is your thing.
Rob-F
Likes Leicas
Teemō;2873028 said:You can't get much more retro than manual focusing helioids. I've not found a solution for cleaning the deep grooves on old lenses so the half-smooth scalloped design is much more welcome.
Maybe a toothbrush, probably used dry to avoid getting any liquids into the lens?
Here's a couple of pics snapped with the Nokton 75mm f1.5. The lens focused fine wide open on my MP 0.58. Bokeh looks very smooth too.
This is the friendly gentleman at the Cosina booth who gave me a run down on the technicals of the new lens.
Voigtlander Nokton 75mm F1.5 @ F1.5 by Jon, on Flickr
Teemō1
If their lenses are anodised it should be okay. On vintage lenses that are only painted I think it is too rough and ruins the finish, particularly on edges. Normally I just disassemble those and soak them in warm water but sometimes I just want to clean them off quickly before taking them out to use.
I have a certain hate for diagonal metal knurling on tools too. Even weightlifters hadn't a good solution for cleaning them as fine knurling is common on some weightlifting gear too. Even worse are the metal mechanical pencils...
Soaking with a cloth and trying to rub between grooves doesn't seem to work as soft debris sticks between the metal surfaces.
My best solution thus far is a soaked wooden toothpick and running through the grooves one by one.
