Voigtlander Ultron 35mm/1.7
-Unscrew sunhood (if applicable).
-Unscrew name ring (front lens element can stay put).
-Remove 3 scews underneath that hold the filter ring in place
-Lift of aperture ring( Not necessary but give more room to work. BEWARE of the click-stop ball-bearing and spring)
-Remove the 3 screws of the part the aperture ring lies over and lift off this part.
-You'll see three screws that should be sealed with lacquer.
-Tighten these 3 screws and reseal (drop of nailpolish)
That should take care of any lens wobble, or at least reduce it significantly.
If I find the time I could take mine apart and take some pictures later today.
Leica III, Ultron 35mm f/1.7 LTM, 400-2TMY.
Erik.
Excellent as always Erik. That is a dream of a lens.
Enviado dende o meu Aquaris X5 Plus usando Tapatalk
