atlcruiser
Part Yeti
Just got the vuescan workign on my v700...so far so good but one question
can anyone tell me how to work the crop set up? I am doing 6x7 negs...I can get it to work fine one fame at a time but the multi frame/batch gets all messed up :bang:
Bob Michaels
nobody special
I cannot tell you although I have been using Vuescan for 8 years. I have always edited the negs first and only scan selected frames one at a time. I am not even sure that you can do batch scanning with Vuescan. But then I have never tried to figure it out.
LeicaM3
Set to Manual and multi frame.
Crop each frame individually.
As you move to your second frame, you won't see the crop of your first frame anymore, but it is "remembered".
After you have cropped all frames, either do batch scan them all or do list scan (you have to remember the frame numbers that you want/cropped).
atlcruiser
Part Yeti
I was able to get some sort of numbers assigened to the frames but cant seem to make it do it again!
Bob Michaels
nobody special
Would the option to have Vuescan sequentially number frames (where you input the file name) work?
atlcruiser
Part Yeti
Got the numbers figured out...I needed to re set the preview window with the multi function on
