Talus
pan sin sal
I’ve had great result with TMAX 100 and 400, as well as Acros 100. Developer makes a difference and scanning tool as well. If you’re really after sharp then it may be worth thinking about moving to 120.
Heh, I do still have three rolls of 36 exposures of Tech Pan that expired in 2002 in the fridge. I have no clue what to do with them for real.I wonder if I still have those 3 or 4 rolls of Tech Pan in the fridge... I should go shoot some landscapes with them, just for you, if I do 😈
In case if not sure, I just enter it in the browser search and hit enter. The trick is to have google as search engine.Heh, I do still have three rolls of 36 exposures of Tech Pan that expired in 2002 in the fridge. I have no clue what to do with them for real.
EI?
Diafine? D76?
With CMS20 I expect it to be better than digital in every aspect (except speed and color...and dust ;-) ) I am not comparing to m11m....but might very well be the case. Scanning has been the limiting factor for me, even using a 3x macro.....
Just don't expect same amount of details as from digital.
135 film is not about details, but color, grey gradations a.k.a. dynamic range .
ISO20 is not too practical, nor 12 Euro per roll. But it is good option, these days.With CMS20 I expect it to be better than digital in every aspect (except speed and color...and dust ;-) ) I am not comparing to m11m....but might very well be the case. Scanning has been the limiting factor for me, even using a 3x macro.
12 euro isn't too bad if you compare it to an m11m - or medium format - but I do see your point. I mix it up with Foma and Ilford... (Not)Suprisingly I end up with a high rate of keepers on the cms-rolls... And, the clean look is not something you always want - but I love it for portraits and snow in sunshine-pictures. That I have the option to use this film, has made me much more relaxed regarding grain and non perfect look of other films....I can just use the others films without trying to get every last bit of performance out of them. After a vacation I always look forward to finding out what I'll find on the cms rolls....ISO20 is not too practical, nor 12 Euro per roll. But it is good option, these days.
I'm just from the days of Shanghai 100 been something like two $ and even scale focusing folder giving plenty of resolution by easy, fast to scan flatbeds from Epson.
Another 5302 shooter! Never thought I'd see the day.Kodak 5302 in rodinal , canon eos 620 sigma 150mm macro . great film but hard not to use a tripod v7oo..![]()
Have you ever used the Eastman duplicating films? I've been using 5302 as an ortho film, rated at 6 ISO, and the absolute lack of grain in that is astonishing. If Tech Pan was even finer grained than that... blimey.
You’re not magnifying anywhere near enough to see the grain. I used to inspect these sorts of films at 250x or 500x on a microscope to check the grain.Here's a full frame, shot with a Summar on a tripod, and developed in Rodinal:
And here's a tight 1:1 crop:
Having wet printed from this film stock, I suspect the "grain" here is mostly digital noise from the scan. It's incredibly grainless. Not the sharpest film in the world, and there's no anti-halation layer, so bloom and flare are both prominent. And, of course, you've got the tonal shifts inherent with ortho film. But it's a joy to shoot and print from.
Your words 'smooth' and 'detailed' trouble me. If by 'smooth' you mean grain-free, bear in mind that to get the same size image on your screen, a 35mm negative is bound to look grainier than a MF shot, simply because it is enlarged more (sorry, that's obvious); and that in digitising a grainy image your scanner will also exaggerate its apparent graininess, which may not be a concern with MF, but becomes more so with 35mm.Can anyone provide me with your personal experiences with films that are detailed and smooth for 35mm?
As a relative newcomer to 35mm with a range of MF cameras I have scanned over 10 years, I have had a less than inspiring time with Gold 200.
I changed to a roll of XP2 and I was really surprised at just how much sharper / detailed the film looked from the same RF camera / lens when scanned through my LS9000.
As 35mm film has a significantly smaller area, I now realise how little I know about ‘sharp’ 35mm films and also how critical this is for me to enjoy the medium.
Could you recommend me some of your favourite sharper more detailed 35mm films to consider?
Any film emulsion has a characteristic resolving power, in part determined by its inherent graininess. But other factors can smudge the 'detail' the film might potentially resolve, notably camera shake and subject movement. So the emulsion doesn't totally determine the amount of detail resolved, but your choice of emulsion will affect the importance of those other factors. Apologies, I'm sure you already realise all that - but in trying to un-pack what you mean by 'detailed', it's worth pointing out that grain and sharpness are not incompatible. Sharpness is really an illusion. Surprisingly, grain can actually enhance apparent sharpness, by the way it renders edges. Tri-X, for example, has a reputation for this. With the right kind of subject it really pops. Have a look at the work of Arthur Steel, for example, to see what Tri-X can do in 35mm. But this has a lot to do with the size and contrast of the important details in the subject. A chromogenic film like XP2 will seem 'smooth' (if you mean almost grainless) with the same 400 ISO - but may lack that pop. (Actually, XP2 produces a look that doesn't appeal to me, but your taste may well differ.)
Personally I like Delta 100 for subjects that need crisp detail - such as landscapes - with fine grain and pleasing tonality. When Delta 100 first came out, it straightaway stopped me messing with slower films like Pan F and Technical Pan. As you are in the UK, that 100 ISO speed means you will frequently be up against detail-destroying factors like slow shutter speed and camera shake; large taking aperture and shallow depth of field; and subject movement. With 35mm you will be juggling these considerations far more than you are with MF. I often have to change films mid-roll.
Seems to me there are two possible outlooks on 35mm:
1) It's small format, and I shouldn't try to do with it what I know MF will do better. I'll concentrate on subjects that are better suited to its strengths.
2) It's amazing what 35mm can do, considering it isn't MF. I'll concentrate on doing everything I can to maximise that performance, within the constraints of the format.
