Website update: mechanical design
videogamemaker
10:00 AM
Reykjavik, Iceland
http://www.finepix-x100.com/en/story/mechanical
Some interesting info. Clicks on the knobs are not with a ball bearing, but with indented washers. I could see that being more durable actually.
Focus ring marks will definitely be useless, from the site:
Fujifilm said:
Positioned on the inner side of the focus ring, two light-sensitive sensors read the signals generated by an alternating pattern of reflective and non-reflective surfaces. Using the signal data, the direction and amount of focus ring movement is determined and transmitted to the lens to adjust the focus. (Photo-reflector focus detection).
It's reading of 0/1/0/1, there is no absolute data.
Fujifilm said:
In order to assure the premium quality level of the X100, we have manufactured almost all key parts in Japan.
Also the "quick on" mode explained.
Quick “ON” Mode
After powering OFF the FinePix X100, it enters a sleep state for up to 20 minutes. If the power is turned ON during this time, the FinePix X100 wakes in 0.7 sec (compared with a cold start time of 2.2 sec.) and is ready for you to frame and capture the moment.
Unboxing videos from fujiguys
http://www.youtube.com/watch?v=qX7Ekht2dAs
http://www.youtube.com/watch?v=XRiQuOhzMiw
The 2nd one is a very boring overview of every button. Like I thought, the jog dial will adjust the Fn commands like ISO, etc.
Wow. Just finished, and these guys are the definition of awkward. The grey haired one reminds me of a real life boss from the Office (american version by Steve Carell). I appreciate the hands on look and the small bits of info, but you'd think there would be smoother operators to be had as the public face of the company in North America.
I'll be very relieved when this camera is in the shops and in people's hands so Tweedledum and Tweedledee (AKA 'The Fuji Guys') can go back to whatever it was they were doing before all this insanity started ... and let You Tube continue with the normal freaks!
Perhaps that should be Tweetledum and Tweetledee? 😀
Honestly.
I wish them the best, but I won't be seeking them out for any info after I get my x100 in hand. I'll probably delete my twitter also, or at least unfollow them and not log in very often.
Those guys are pretty frustrating. The camera has so many cool things that I want to know more about and they barely show the details of anything.
Well, since these guys are from marketing, and are not very technical, we can't expect them to be capable of guessing our questions.
Maybe it would be a good idea if we'd open up a dedicated new thread where we'd collect all our questions to them, and then tweet them a link to our collection of questions?
I looked through the new page of the Fuji X10 site, and I discovered that there's a new video available
Either you follow the link in msg #1 and go to the bottom left, or you click this link for a larger view. No substantially new info, but a nice visual to get your GAS attack going 😉 .
Nice, thanks for that.
Two interesting things I noticed from the spec sheet (from the "announcement thread by Precision Camera)
Shutter speed (with mechanical shutter) *1/4000sec at F8 or smaller aperture, 1/1,000 at f2
Good thing for that ND filter. I am guessing this is because since the shutter is immediately behind the aperture, that at f/8 and smaller the aperture is small enough that the shutter totally obscures it faster than when it is wide open. Not necessarily a bad thing, but something people need to be aware of, I think.
Also battery life is now announced as approximately 300 frames. I think I'll probably buy a 2nd battery, for longer trips, but 300 seems quite good.
They should give one to Steve Huff or Jeff Ascough or something... a real photographer with a great personality and huge online following that will be able to take amazing photos - hearing marketing dudes talk about the most basic of features in detail is sooo boring.
You mean this takes photos... I thought we were only supposed to be in awe of its outer beauty...
In all seriousness... do you guys really expect this to be a lemon in the IQ department?
Nope, otherwise I wouldn't have already put down a 100 dollar deposit. I am just curious. If I could already take delivery, I wouldn't care, I'd be out taking photos. But I want to see just how good it is at iso 6400, and how well it can do with extreme contrast (dynamic range).
I'm sure it will be good. I'm hopeful it will be amazing. I want to know just how amazing.
Interesting. You can adjust aperture and shutter in 1/3 stops with the jog dial:
X100 lets you easily set exposure in 1EV steps with the Aperture
Ring and Shutter Dial, but for more detailed adjustment in 1/3 EV
steps, you can use the Command Lever to fine tune the aperture
setting and the Command Dial to adjust shutter speed.
Also auto ISO information:
ISO Auto automatically adjusts the ISO within a range of ISO200 to
ISO3200 when it is not possible to get an appropriate exposure.
With this control, you can freely set an ISO Auto sensitivity ceiling
up to ISO3200 and a minimum shutter speed down to 1/4 sec.,
highly useful as a safeguard against unintentional high-sensitivity
shots and blurring caused by camera shake.
Whoah! Double battery life if using the OVF:
OVF Power Save Mode
If you turn this mode on when using the optical viewfinder, the
power saving system is activated, doubling the maximum number of
images per full charge from 300 in normal operation. It is ideal for
getting the most of your battery capacity and getting a few more
valuable shots out of your charge.
��Maximum shots in the case of a fully charged NP-95 lithium battery pack, based on the CIPA
(Camera & Imaging Products Association) test standard.
Auto focus has an "auto selection" mode. Probably chooses based on motion, that could be really cool. And the live view magnification automatically zooms in on the area you have the AF point set to. very nice.
Despite many contrary opinions, the <Fn> button can indeed recall 11 functions, while using the jog dial for multiple choices where appropriate [and NOT only controlling flash commander mode]. Included in the 11 function choices is a "custom setting".
I am satisfied that I can make the X100 do what I want and even what I don't need. Time to leave RFF, read reviews when available, seek to handle a real camera and buy one.
The Fuji X100 is indeed my [one-camera/lens] ideal.
I don't remember anyone ever saying Fn wouldn't be assignable to more than just ISO.
I do remember saying the focus ring wouldn't hold absolute position, and snap to zone focusing not being a feature, and the jog dial controlling the Fn button and now being confirmed right by all these accounts.
I could imagine if you hold the Fn button and then use the jog dial you might be able to switch between the different functions... but this is purely my imagination, I have no proof of this being possible.
From the menu screens on the japanese website, it looks like you program what the Fn button controls deep in the menu. Then when you press the Fn button the jog dial will then alter that setting up or down (assuming it is a value change. DOF preview probably just needs the Fn button press)
Out of the box, press Fn then the jog dial alters ISO up and down.
If you prefer, dig into the menu, find the Fn setting, change it to White Balance. Now when you press Fn, the jog dial will alter WB through the various presets.
